Wow. Just took Winklers off my shopping list. I can accept that some lemons may make their way out... But the more costly the knife, the more scrutinizing I am. Thanks OP for this thread.
Twindog,
Wow! what a piece of crap! First let me say if you will send me your address I'll send you a new knife. Feel free to test it too. ( I would prefer you not cut a nail, that seems a little extreme and I don't really intend this model to cut steel. If you need to cut steel I make a Rescue axe designed to cut sheet metal that would probably hold up.)
About the time that knife was made was when I implemented some new inspection and testing procedures. As with that knife, we had a few come through with similar problems. This came from some issues with heat treating. That knife was most likely made from 52-100. I found out that this particular batch needed to soak in the high temp salt for no less than 1 full hour. We had only been going for about 15 min at heat and a full run of about 10 knives came out soft. I thought we had gotten them all but I guess not. Basically you tested a knife that had an improper heat treat.
We make more knives that I can possibly do all myself. It also has taken a while to get the guy's to a point that they can recognize the possible problems that can arise that are not visual. Each blade is now checked after heat treating and before the handle goes on to assure it is up to standards. There may be one that slips through now and then but it is rare. Humans make mistakes but we are trying to eliminate all the problems we can. However when one does come up we will take care of the problem.
Daniel
You should read this thread, not just the OP. You'll see how this maker fully resolved this issue to the OP's resounding satisfaction. Good grief!Wow. Just took Winklers off my shopping list. I can accept that some lemons may make their way out... But the more costly the knife, the more scrutinizing I am. Thanks OP for this thread.
IMO, it would be helpful if a Moderator would edit the title of this thread and point out Daniels post...
Man, this shows a guy not to go into the field with an unproven/tested tool no matter what that tool might be. Everything should be harder than a nail...
..... I think there are many blades available (both more and less expensive than this one) that could have dealt with this and much more mate.
Twindog,
Daniel
Mod did the right thing - contacted Dan. Giving the maker an opportunity to resolve this issue to OP satisfaction. End.
People who don't pay attention, won't pay attention. No amount of hand-holding will lead them to the goal.
Besides, maybe the OP could edit that in. The less moderators do, the better. You really don't want us telling you what to think.
I've had some weirdness with some 52100 lately myself. I've trashed 8 blades so far and wasted many hours. Found a new supplier.
Done. Thanks, Esav
