- Mar 8, 2008
G-pig dried his handles before hanging them. He just did/does most of the shaping work green. I have an oak handle from him on a Spiller Jersey pattern and it's totally dry.
What size axes are we taking about? Pretty much any woodworkers supply store that carries lumber like Rockler, Woodcraft, a local similar place, etc. should have hardwood suitable to the task. Probably including hickory. I was in a Woodcraft several weeks ago and there was plenty of hickory, from 4/4 boards to big live edge slabs.
A good supply if your only option, but very expensive for the sizes needed. Far cheaper to buy a good hat pre-made handle and thin it. Or split out a stave.
Thank you Kevin. Sound advice and when you stop and think about it...common sense.You could use a branche, but it depends on the shap you want? And it can't have any ofshoots, since that will become fracture points. But since branches aren't straight, it usually means that you will have to make short handles. Branches with a natural curve that you like are usually stronger then the same length of wood from the trunk where the wood is cut to shape. Grain orientation is better. But is like finding a needle in a haystack, and not a sound business model. Al handles that are manufactured are from the trunk for that reason.
Any idea on the costs?
Branches are reaction wood and prone to warping. A straight clear trunk is much preferable.Gentlemen, if I may, please correct me if I'm wrong but, should an axe haft come from the trunk of the tree or would a branch be ok? If a branch would be ok, what minimum diameter would ok to use?
I was able to cut a few hickory branches off a tree that is destined to be cut down. I hope to get the tree when she comes down. Now, this brings up another question, I realize some of you all say that green wood is ok to use and some not. I'm not an expert or even a novice but let's say you wanted it to age and "cure." If you were going to deal the ends with varnish or whatever to help with splitting or checking, when would you seal the ends? Right away?
Hey, enquiring minds want to know this stuff.
I paid ~$60 after tax for an 8/4 board 40"(?, I'll double check when I get home) in length and ~14" wide - straight and clear. I can't remember specifically how many board feet. It's more work than working a Link, e.t.c. But I enjoy the process, and I'll get at least 5 full size axe handles and god knows how many hammer handles from it. All told a good investment for me.
They had 4/4 hickory boards on a pallet for dirt cheap, but you'd have to dig for something clear. 4/4 will work for smaller axes and hammers, e.t.c.
You are not wrong. I've done this with brand new $10 ash shovel handles. You can get 3-4 hammers out of one and perfect grain every time.So I just seen wheelbarrow handles at my local Home Depot. They were about $15.00 each. Now I’m not saying that’s cheap. But if you were looking for blank material to make a straight handle. This could be another option.
Edit : I guess my point is. The grain on the wheelbarrow handles was better than the grain on the axe handles that were right next to them.
I'm thinking branch wood might be ok for hatchets as long as there are nothing shooting off or out? All straight wood?Branches are reaction wood and prone to warping. A straight clear trunk is much preferable.
https://en.wikipedia.org/wiki/Reaction_wood
Hickory...and I took some of the nuts down to my MIL's and I plan on planting them before Thansgiving. I prolly won't be able to use the wood from them at my age, but somebody might. Squirrels?Yes thats right, so long as it doesn't have offshoots you'll be fine. I do hope you know what kind of trees your getting the wood from, as not all tree species are suitable....
