- Oct 5, 2011
Maybe you are over thinking this? I can't see a reliable way to mark out your cuts, so yeah remove the wax first.
Concentrate on leveling the wax lumps and bumps from all six faces so you can set a square properly and mark it out, then have the stock behave in plane as you saw. If you are using a table saw, take your time, read up on basic safety, maybe get some seasoned help and/or be thoughtful if you are new to this. Use a push stick. These tools are notoriously unforgiving.
I have a couple of sharp 4" card (or cabinet) scrapers for removing wax, wood glue, etc. Pop the waxed stock in the freezer for half an hour to stiffen the wax. Then usually two or three skewed strokes and surface grain gets sheared with the wax. Takes a nice clean layout without wiping them down but YMMV. A sharp hooked burr on a straight-edged knife works almost as well if you are careful. Also if you decide to use solvents and rags to remove the wax - please reconsider as this stuff will burn like there is no tomorrow. Good luck to you.
