If you can swing it, get at least two gallons ( since 5 gallons is the same cost as three gallons, that is why I recommend the 5 gal pail, only $16/gal.), especially if you are doing 14" blades in 1095. It takes a fair bit of oil to properly quench a big blade. If you are doing one at a time, a smaller tank will work, but when you start doing several knives at a time, you will need 2-3 gallons of oil, minimum.BTW, A turkey fryer pot makes a great quench tank for 5 gallons of oil.
The blade should stay in the quench tank until you can remove it by hand. Then you cool it to room temperature (running water is fine to do this) ,and as soon as possible do the first temper cycle.
I'll give you my 1095 quench procedure:
Normalize the blade three times. You want no build up stresses in 1095.
Austenitize[/B at 1450F, with a one minute soak to assure complete evenness of temperature.
Quench in fast oil. Straight in, tip first. Count to five, quickly pull the blade out ( the blade ,and tank,may burst into flame, that's OK, but be prepared, so you don't panic), and sight along the spine to see if it is straight. Immediately straighten any warp by slipping the blade in a vise ( prior to the quench,open the vise so that the jaws have been cracked open just enough to allow the blade to slide in. You don't want to waste a second doing this during quench) and twisting/bending as needed. The blade is like rubber between 900F and 300F,so don't be faint of heart, but do be quick. If no warp is found, or after a fast straighten, stick the blade back into the quench and let cool till you can hold it with your bare hands.
Check with a file to assure the edge is hard - it should sing across the blade edge with no bite at all. After the quench ,and before the temper, 1095 is very brittle and can be broken easily, so don't drop it or try to bend it. Temper as soon as possible.
Wipe off the oil, wash the blade with soap and water.( If you don't wash it well your wife won't ever let you temper another one in the oven)
Temper by putting the blade in the oven at 475F, and bake for two hours. Cool to room temp (water is fine to cool it off), and repeat the temper again.
Stacy
