Brian, I notice that your technique is to apply knife to belt about 1" from the heel, then back towards the handle, then along the full length of the blade. This means that the heel receives 2x the number of passes compared to the rest of the blade. One of the problems I found with the original WS is that the heel can acquire a divot over time. Have you found this to be a problem?
Thanks
The idea of me doing that is so I don't grind down the bolster at the heel of the blade, or any other non-sharpenable surface (like the handle of a folder or something). In practice I haven't noticed any real deformation of the edge near the heel doing this technique.
But, I have to say that the vast majority of blades that I have seen, *especially* kitchen cutlery, have geometry problems near the heel anyway. These problems include wider or narrower bevels, bevels at different angles than the rest of the blade, and just plain blunt areas in the last 1/4" to 1/2" near the heel. In these cases, I'm only making the blade better by grinding it to a sharp apex, and certainly not making the bad cosmetics any worse.
Now this gets a little strange, but I'll try to explain it properly. I find that in nearly all the sharpening I've done, the middle of the blade gets the most attention. This is particularly true on bench stones, as the middle is almost always touching the stone. But both ends of the blade get the *least* amount of contact time on the abrasive. If you think about what area of the blade is touching the abrasive at any given time, the last 1/4" to 1/2" of the blade at the heel and the front 1/4" to 1/2" at the tip get the least amount of contact time. I find that in at least 3/4 of the blades I sharpen, I need to spend extra time at the heel, the tip, or both, in order to grind to an apex and get a burr on the full length of the blade. This is actually one of the *great* things about using the WSKO freehand: I can spend extra time very easily on any part of the blade, and not overgrind the rest of it!
Finally, I *theorize* that I'm using less pressure against the belt than someone would when using the guides. I'm not noticing any real deformation of the edge bevels and I'm definitely not grinding anywhere near enough to make a "divot" in the heel. Perhaps it has more to do with how the original WS instructs the user to put the heel in the machine with it off, then turn it on and start moving it then? I'm only guessing.
On the other hand, I "made up" this technique of starting the grinding slightly away from the heel of the blade. I wonder if someone who's used a belt sander to sharpen a lot of blades would think it was a good or bad idea? I'm open to suggestion and criticism.
Brian.
