- Mar 8, 1999
Here's a report from the handle meister on the test WWIII (as you can see, going is a bit slower than I imagined, due entirely to delays created by me):
Although I leave total technical control to Robert, I think the epoxy will look better, as I want to keep brass away from this project. Any thoughts?
Craig Gottlieb
Gurkha House
Blade Forums Sponsor
The day started out poorly, but ended up OK I think. What I learned:
As I suspected, the 3/8" handle material you sent won't work with the ferrules in place. By the time you "fit" the handle inside face to the tang there is not enough material left to "fill" the ferrule. (The top of the ferrule sits proud of the handle by over 1/16".) The inside handle faces must be "fitted" or "scribed" to the tang because the tang is not flat. It tapers from front to back and from top to bottom. This amounts to almost 3/16" per side, or half of the handle thickness. It would be impossible to flatten the tang enough without butchering the knife. The only option is for us to remove the ferrules as we originally planned.
I began the process of fitting the handles without the ferrules. I like
the results very much so far. The 3/8" material gives a nice grip size.
The look without ferrules is rather "tactical" (if you'll excuse the
buzzword). I've shaped the handle and I'm in the process of working my way through finer grits now. The notch from the ferrule will have to be dealt with, but we can either fill it with epoxy the color of the
handles (the easiest), or fabricate a brass "filler" for the area. Let
me know your thoughts.
"Fitting" or scribing the handle to the topography of the tang can be
either fairly straight forward, or extremely time consuming depending on how fussy I try to make the fit. The time involved seems to go up
exponentially as you attempt to improve the fit. My thinking right now
is that we need a "no-rock" fit, where everything sits flat, but not a
"no-gap" fit. I will use colored epoxy dyed to match the micarta as
closely as possible. This should fill any small gaps at the edges of the
tang. I think it will look OK.I know it will provide a good seal and
more than adequete strength. The first one should tell the story.
The tang drills quite easily with high speed steel drills. We won't
need exotic drills unless the one I worked on today is an exeption.
Craig Gottlieb
Gurkha House
