- May 18, 1999
And a Ryobi tool similar too the Dremel beats the Dremel hands down IMO.
I have both an I find the Ryobi much more flexible in its uses than my Dremel.
And the switch for the speed control is a rotary type that your hand doesn't interfere with, and the on/off switch is also located in a better place close to the speed conntrol.
And I don't recall for sure, but I think it may be a tad faster (rpm) as well.
I use the Ryobi for fine detail carving on the fancy Flutes I sometimes make.
I am with Cougar and believe a drill motor would work better if you don't have a buffer. And one of the smaller 1/4" high speed drill motors would be best of all.
BUT YOU STILL WANNA BE CAREFUL!!!!!
The small rotary tools like the Dremel can grab the work stock and pull your hand into the work and if it's the edge of the khukuri, You are Cut!!!
There is no time to holler "DON'T" or "DOH."
>>>>---Yvsa-G@WebTV.net---->®
"VEGETARIAN".............
Indin word for lousy hunter.
