Matthew Gregory
Chief Executive in charge of Entertainment
- Jan 12, 2005
I can't get any belt other than Norton Blaze to work for me. No luck at all with any of the 3M belts. No idea why.
Have you tried the VSM ceramics? About half the price of blaze, and I actually find them to last longer with how I grind.I can't get any belt other than Norton Blaze to work for me. No luck at all with any of the 3M belts. No idea why.
I have 15 blades of D2 ready to send out for heat treat. First time using D2. What is the optimum hardness for D2?
Well, I feel your pain. I tapered this CPM M4 tang last night at 62 RC. Ate up a new Blaze 36 and Combat 60 doing it.
Glad the bevels were ground about 90% before HT. I'm leery of grinding a tapered tang before HT because the tang flats are usually my reference for what flat/parallel/straight is relative to the blade.
No. I did it the way you describe. But I made sure it was straight first, once the tapers are in it's just harder to see/indicate that it's straight. Especially if there's distal taper in the blade.
Maybe some confusion. I'm worried that if I taper the tang before heat treat, and there's warp, it won't be as easy for me to straighten it because with no flats, only a tapered tang and a tapered blade, what is the reference for straight?
With the tang flat ground through HT, I know it's straight when it lays flat and even. Then scribe my centerline and taper away.
Are you hollow grinding before flat grinding those tangs, bud? Shouldn't take that much, even with M4. Scoop out a heap of that material with a wheel, right over those holes, and make the task easier on the platen.
Another good tip!
