The super steels can be a pain to sharpen...because they are so durable. I was sharpening a Strider SNG for a customer a couple months ago. It took me about 20 minutes to sharpen and strop on my Lansky set up. It wasn't that big of a hassle but I did notice a distinct difference. Yet that very same durability means it won't need to be sharpened for a long while.
I hate sharpening these new super steels. Why? Because I was collecting knives before they were popular.
I wonder when the knife world will want to go back to a soft steel? I wish one day that would all take a turn in the other direction.
I remember my old Gerber in the 80's was so hair popping sharp because it only took a couple licks on the V-sticks. I don't know what the steel was and they did not give out that info.
I knida miss that kind of "sharp" on a knife because I want ti USE my knives and not worry about cutting on a plate of food and have to sit on a sharpener. I wish we had the same knives today (liner locks, frame locks, tactical knives ect) but with the soft steel. They would be cheaper too!
What do you use to sharpen your knives?
Jens, some say that natural stones won't work. But you're getting good results. I use SiC and India stones and some say those don't work on high vanadium steels.? DM
So that problem would only be with the finer abrasives as in high grit numbers?Coarse Aluminum oxide (around 100-300 grit) will sharpen the most wear resistant steels because it has very little interaction with the Vanadium within the steel even though Vanadium is harder than Aluminum Oxide, Silicon Carbide, and way harder than any Natural stone. Because the abrasive is so much larger than the carbides it just scoops them out with the rest of the steel matrix.
As the abrasive gets finer the problem with abrasive hardness becomes more apparent and an actual problem in sharpening. The abrasive starts to equal the Carbide size and because it's not hard enough to cut through it the result is the Carbide dulling the abrasive making it polish the bevel excessively and lose cutting ability. The edge will "sharpen" but it will be lacking in many areas because of the inferior abrasive.
From which grit number up would you suggest to abstain from natural stone?
Just checked. Seems my edge pro stones are made from aluminum oxide and silicone carbide. Would that explain my good results?
Oh cool. Thank you.Good results? That's subjective, your good and my good could be two completely different things.
Up to about 1000 grit JIS most stones will cut most steels, beyond that it gets complicated as alloy content, HT quality and hardness all start playing into what works and what does not.
It's all about the relative hardness of the material. Hardened steels come in at 7-7.5 on the Mohs hardness scale, even super steels. Carborundum and Silicon Carbide come in at 9. Natural stones will work just fine so long as you know the hardness of your stone. The same goes for manufactured stones. Being mostly ceramic, they inherently have a hardness of around 7 but contain abrasive inclusions like powdered metal and clay. The over all hardness of the stone doesn't matter because it is just a binder for the abrasive inclusions. Diamond plates (with diamond being a 10 on the scale) are a no brainer.
