- Mar 30, 2015
'Super steels' wouldn't be 'super steels' without the carbides that make them so. The carbides in super steels are WAY, WAY harder than Mohs 7-7.5; more like Mohs 9+, in the case of vanadium-heavy steels (30V, 90V, 110V, etc). Natural stones of any kind won't touch that, as they're nowhere near hard enough to abrade those carbides, and therefore will stop working as the carbides get in the way at finer grit levels. Even at very coarse grit, lesser abrasives won't cut or shape the carbides and will instead just scoop them out of the matrix steel, limiting how refined the edge can be made. At finer grit, the less-hard abrasive is no longer big enough to dig down between the carbides, which means it only 'skates' across the carbides without cutting them, and effectively stops working.
The Mohs reference for hardness is misleading as well. Being a completely unitless scale, instead simply an ordinal one, Mohs doesn't indicate the true degree of hardness difference between materials, instead only indicating that one is ranked harder than another, no matter how much difference there likely is between them. It's the same type of ordinal ranking as might be seen in posted race results, only indicating the finishing place of each contestant (1st, 2nd, 3rd,..., 8th, 9th, 10th, etc), regardless of how fast or slow each was.
On a scale of actual measured differences, when comparing basic steel hardness to the hardness of the carbides, steel itself (w/no hard carbides) is about 600-800 on the Knoop scale, and vanadium carbides are around ~2800 Knoop (at least 300-400% harder). Even 'softer' carbides, like chromium carbides in steels like D2 and ZDP-189, are about 2X as hard as the steel matrix itself (chromium carbides = Knoop ~1300 or so). Natural stones, like Arkansas stones, are no harder than ~ 825 Knoop (the hardness of the novaculite natural abrasive in them).
A more meaningful hardness comparison, for reference:
Basic, hardened cutlery steel w/no hard carbides: ~600-800 Knoop
Novaculite (Arkansas stones): ~825 Knoop
Chromium carbide (D2, ZDP-189 are very heavy in it): ~1300 Knoop
Tungsten carbide (carbide pull-through sharpeners, also found in some cutlery steels): ~1400 Knoop
Aluminum oxide ('corundum' or 'Alumina'; Norton 'India' stones, and most ceramics of alumina): ~2100 Knoop
Silicon carbide ('carborundum'; Norton 'Crystolon' stones, wet/dry sandpaper): ~2600 Knoop
Vanadium carbide (significant in S30V/90V/110V steels and many others like them): ~2800 Knoop
CBN ('Cubic Boron Nitride'): ~4500 Knoop
Diamond: 7000 Knoop
David
Where would ceramic sharpening media, such as the sharpmaker rods, fall in this lineup?
