If you're asking how strong a folder should be, it is my opinion that you need a fixed blade.
Not true. I would not buy a folder unless I knew the pivot and lock would be sufficient for my uses. Granted, my uses are sitting idly in my pocket until I occasionally use it to open a package/letter, I would still not pay good money for a knife unless I knew it could do what I am asking of it. While I don't advise using a folder to baton, don't be rude or call the OP's wishes dumb, either help with suggestions of strong folders, or don't post anything negative. Keep it civil, respectful, and helpful.Perfect answer, if any doubt crosses your mind when it comes to any task your about to perform with a folder, you should be using a fixed.
hey guys i just wanted your opinion on how strong or how long a folders lock up should be or last.. for instance do you expect to do some heavy batoning with a folding knife to still have a solid lock up after you use it to baton? no side to side or up and down blade play.
I would never baton a folding knife. I would never baton a fixed blade knife. I would use an axe. Batonning is knife abuse. Just my opinion, as there are many baton fans here.
has anybody batoning with there folder have it last with out blade play or do they all eventually end up having blade play.(non fixable blade play that is)
If you need to baton with a folder - make sure to unlock the blade first. This way you will not put unnecessary strain on the lock. Than any folder would be able to baton with minimum damage.
