With an appropriate heat treat ELMAX is better than S30V in every aspect. Its much tougher, more stain resistant, easier to sharpen, and holds and edge longer. Its my favorite all around steel for folders and fixed blades at the moment. What I really love about it is how stain resistant it is along with its ability to resist damage. Its a really low maintanence steel that IMO really shines in harder use scenerios where edge damage can/ will occur. S30V will tend to chip where ELMAX will tend to roll and can be easily repaired on a ceramic stick.
To my understanding at full hardness (62) ELMAX will beat S90V at a lower hardness, like 59 or 60 and will beat M4 at a hardness around 63. S90V at full hardness will spank ELMAX in edge retention and M4 should beat it as well but not by as big of a margin. But even with a full hardness heat treat on all 3 ELMAX will have the most corrosion resistance, be the easiest to sharpen, and will be much tougher than S90V but not as tough as M4.
I think the biggest problem with doing cut tests with the 560 is the thickness of the blade. You always end up with a wider angle on the 560 as opposed to something like the Para 2 with its thin blade. I don't think of the 560 as a great slicer, if you want a great slicer go for something like the Benchmade 746 with its super thin blade. The 560 was meant for hard use and is built to withstand lots of use/abuse. You are going to give up some slicing ability in order to get those attributes. No knife can do everything well, that is why they make all kinds of different ones for you to buy! And really, who doesn't want a "reason" to buy more knives?
With rare exceptions, no steel is "not for me." Almost all of them will get sharp enough to shave. Most of them will keep that razor edge for longer than just shaving the hair on my arms. Most of them again will maintain a razor-to-keen working edge for most tasks for plenty long enough. ALL of them will need to be re-sharpened eventually. I've come to the conclusion that until someone comes out with a real live "light saber," NO knife is worth buying purely for the steel used in it.
Ever used M4 at 64 or Sleipner at 61? May make you change your mind. Those are some amazing performers.
I believe S30v can be made sharper but ELMAX has better edge retention and strength.
