I’m curious to see if there will be a toughness increase with the lower aus temp! Thanks for this! I haven’t tried anything else but a 1925 aus temp. No time for testing sadly.I did some coupons for our charpy testing. Here’s the results:
Z-tuff hardness was:
1900fx40min, cryo 1h, 400f temper, 2hx3. Rc58-60.
1975fx30min, cryo 1h, 400f temper, 2hx3. Rc60-63 (most readings were Rc61/62, but not all were consistent.)
2050fx20min, cryo 1h, 400f temper, 2hx3, Rc58-64.
I wonder what kind of toughness could be gained with a marquench. Have you tried this on any of your samples? Or do you not have a way to do it? This was recommended to me by a European maker, with mod A8.I did some coupons for our charpy testing. Here’s the results:
Sadly! I would like to see if there are any gains! Some people claim great results.I’m not set up for marquench at this time.
I ended up with 57-59 rc with that heat treat. The other one was right at 60 consistently.1875-1000 would likely lead to much lower hardness than 1900-400, which may explain the observed differences.
I should have clarified, the other test knife was austenized at 1925, cryo, and triple tempered at 1000. I’ve still yet to break it, and I’ve beat the hell out of it. It’s held up to more abuse then 8670, with a spring tempered spine.1875-1000 would likely lead to much lower hardness than 1900-400, which may explain the observed differences.
No I haven’t. But it would be interesting to try it. I actually never thought of that. The higher tempering definitely gives different results. I just haven’t figured out if the results are better or worse. But I guess it depends on the knife and the use!Have you try higher austenitizing temp like 1950 or 1975? I believe higher aus temp will lead to more carbon in solution (more martensite and RA) so more carbide precipitate with 1000F tempering.
I have been heat treating Ztuff using a 1950 austenitizing for 30 minutes with a plate quench and three 1000 degree tempers, no cryo. The hardness has been coming out at 59-60rc, heavy on the 60rc side. I have not done any destruction test but from use in the field over the last year i have had better edge stability, less micro chipping, than 3v with the same heat treat.
If you did cryo with 350 or 400 temper, you would get the Rc61 or a bit more you are looking for.
