Willie71
yes we loose big time on our exchange. My order will hit 10k for sure but I use a lot of it and like z wear a lot.
For a order it’s a min two month wait so we have to plan a little ahead. I think there is a balance in how tuff we need to go on a knife .
Z tuff is tuffer but I’ll give up a little on tuff to have a better edge holding . So I think z wear fits my needs perfect.
VSM is my go to belts 60gr 120gr
I've been working with and heat treating S7 for almost 14 years. It is the toughest steel I ever used. As far as edge holding, it falls in between O1 and A2 at 58/59 rc. Of all the blades I've made in S7, never had a complaint about edge holding and it's easy to re-sharpen with minimal sharping tools. CPM 1V is one I've starting using this year and it's right up there with S7 as far as toughness but with a little better edge holding at 59/60rc.
Scott
Yes, I agree. Toughness can be defined different ways. I'm referring to "impact" toughness which a blade will come up against in extreme hard use. I don't know of many steels that can handle two hits from a 308 cal. at 53 yds. with very little deformation as you saw in my Instagram post a couple of months ago. I will be watching how others that work with Z-Tuff, to see their results. I always like a tough hard use steel.As Fredrik Haakonsen once said in open forum:
“If I had come across a PM steel tougher than A8-mod I would be using it myself. ”. By the time he said that, I was still a newbie regarding steels, and was obsessed by pm steels and datasheets. Now, it’s a bit different. Even Fredrik admits that S7 is tougher than A8mod (if knife blank is cut in the rolling direction of the steel, not perpendicular and the heat treatment is made right), so, Scott, S7 is one of the ideal choices for a hard use blade, let alone a really big one, designed to take high impact in every swing!
Willie71
Yes Dennis told me he as one of your knives. I’ve done a few chef knives in z wear to and took them down to 0.004 at the edge . I hand sanded mine to 600 gr at 63/64 rc wow that was a blast hahaha.
All my blades goes to Peter’s for heat treat.
I’ve done hunting knives in it to and guys were very happy with it.
I guess I’ll have to get a few pieces of z tuff to test out someday.
That sounds kind of like the old Kentucky line "when my rich uncle gets out of the poorhouse,"Once our money is released from court........
Scott
I am wondering how tough this Z Tuff will be to finish. I have no problem with 3V at 60-61 on a big hunter sized blade, but I am used to big knives in W2 and CFV so I may be a bit of a masochist. For me, the heavy lifting part of of hand sanding is done with 320 and 400 grit EDM stones.
A8mod has been sent for grinding. Z-tuff is on my bench waiting heat treat. I’m really curious regarding the improvement, if any with cryo/low temper, compared to recommended heat treat. This is really interesting to me. I love nickel bearing steels like 15n20. When I glanced over z-tuff a few years ago, I missed the nickel content. The potential for a pm high alloy Damascus isn’t lost on me either. Big step up in equipment though....
15N20 is excellent. It held up great when I used it to gut a deer. I always use my blade to cut up into the breast bone. 15N20 excelled at this task and the edge held up perfectly with the force and torqueing required to cut into that bone. I have the edge run thin and hardened to 59 rc. I used the .130 thickness
Scott
Great to know A8mod was sent to grinding!
No doubt cryo and low temper heat treatment will improve Z-Tuff toughness, let’s see how it compares to the others (A8mod, NZ3). Do you have some S7 steel pieces to heat treat? Would be great to compare, also!
Regarding 15n20 low toughness first results, I’m sure something went wrong with Larrins samples, because this steel has the potential to be much tougher than first toughness tests indicate! It’s not a 0,5% Carbon Steel, but well heat treated will have a very fine grain, wish helps in the toughness department, as the nickel content. I really like you are giving 15n20 a second chance! I wouldn’t be surprised if it where tougher than AEBL! Let’s wait!
I'll try that next time. Even at 59rc, edge holding has been excellent.
Scott
