- Sep 1, 2004
I know, I know, not another Leek thread...
I jumped on the ZDP-189 Leek when it first showed up. I was delivered one of the very dull ones, my first disappointment, and spend WAY too much time getting it sharp. I wasn't dismayed by the dull blade though, it was a new steel for Kershaw, and these things happen. I loved the lighter weight than my other Leek, and it sure did hold that edge once I was able to get it sharp. For a month, I was in love.
Then, one day, I needed to bore a tiny hole in my kids swingset slide where rainwater was pooling. I already had a hole on one side, which I had made with my Rainbow Leek. The slide had settled a bit, and water was now pooling on the other slide. Out comes my new fancy expensive Leek, into the semi-soft plastic, work it back and forth gently, peeling away a sliver of plastic shavings with each turn, slow, slow, and *snick* 1/8" of the tip breaks off. WTF
??? Soft plastic vs. super-steel should be no contest. Sigh. So out comes the coarse steel, and I have a quasi-tanto Leek...
Then, I take the knife out in the field. I'm a scientist, and SCUBA dive all over the Chesapeake Bay. We dove in the lower Potomac, and I ended up cutting a few things on the boat between dives- some rope, a couple cable tie ends, etc. It was a 14 hour work day, and I crashed in bed shortly after I got home. The next morning, I took my Leek out to clean it well. I was shocked to see the blade was covered in rust, with small spots/pits aready evident. The knife would no longer fully open automatically either- it would open 3/4 of the way and then stop. Holy crap, this stuff rusts more quickly than any steel I've ever seen. :thumbdn: I've taken my Rainbow Leek in the field many, many times with nary a rust spot. I've had it for years and it still opens perfectly.
I don't care how long ZDP-189 holds an edge. For me, as a user, this steel just will not cut it. I guess I'll be in the market for a new blade to put in this expensive titanium Leek handle.
