ZT 0200 "Baby" Just Arrived! Really!!!
I thought this might be of interest as a stand alone thread, so i copied it from a related thread that was more for a wishing it were available knife,....
......and now i have one!
Well,.....i didn't have to wait as long as i thought for my "baby" ZT 0200. I spent several hours yesterday and into the wee hours of today to think thru and execute a cesearan on a full size ZT 0200.
I just "knew" there was a baby in there! ;)
I still have to get a keen edge on the front half of the blade,.....but that will have to wait until i can order some sharpening equipement. All the work done so far was with my jewelry repair equipement,......made up mostly of a Foredom Flexable shaft machine and using thin stone separating discs, and an assortment of files.
I first tore the knife down to get at the steel liners, and made a decision to save as much of the original length as i could and still end up with a 3" blade length. I used a magic marker to mark the outline, and decided to keep the 3rd set of spacer holes intact in order to have the upper part of the knife fill my palm.
I cut one liner at a time, and after i roughed them both out i made a couple of aluminum rods to fit in the two outermost spacer hole sets. (from a slightly thicker knitting needle that i cut & thinned down) These were fitted tight so that the two liner halves could be matched up perfectly in the final finishing.
After finishing the steel liners i put the frame together with the spacers and G10 scales attached,......but left out the blade. The scales, of course, hung way outside of the liners at this point,.......but i was able to trim them pretty quick using a separating disc to remove most of the excess scales,.....followed by one of my old diamond setting steel burs to blend in close to the steel liners. A final fitting with a rubber abrasive wheel and a quick polish with jewelers polish made the butt end look pretty nice.
I originally was planning on either cutting the 3rd set of spacer holes out totally,......or leaving at least one hole on a single liner to allow for attaching a cord. I chose to eliminate the cord attachment idea,.....and opt for the longer handle in my palm. I think i made the right choice as it fills my hand very nice! Also, the 3rd set of functional frame screws keeps the frame stronger than just 2 sets, i would think.
I then took it apart again and washed it all down,.....before re-assembly with the blade in place. I wanted to be sure how to profile the blade before i cut it. Reinforced tape was placed over the blade's sharp edges while i worked, and i used magic marker again to get the profile i wanted. I actually made a cardboard sample of the blade shape, and traced it over the blade with the marker.
I then worked slowly to keep heat from building up in the blade, and used my cutting disc again over about an hour to get thru it. Repeated dippings in water also helped. This blade is HARD,......and i wanted to keep it that way!:thumbup:
I then freehanded a decent edge base to work from,......once i get some sharpening equipement in. The blade would probably benefit from a bench grinder's re-grind,.......but i'd loose the tungston coating so i'll wait to see what kind of edge i can get without going there.
Anyway,.....all in all a fairly nice "baby",........
...i guess all my jewelry repair experience payed off again. ;)
BTW the weight of the original was 7.9 ounces and the baby weighs in at 6.8 ounces.
Overall length dropped from just a tad over 8 3/4 inches to 7 1/8 inches.
Closed length shrunk from 5 1/4 inches to a more pocketable 4 1/2 inches.
......and the blade is a fiesty 3 inches.
Save for a section at the top where i had to re-profile the blade to come to a point,......NO high tech coatings were injured in the making of this knife! :D
Please note ADDITIONAL PHOTOS with the knife broken down at post #21
Joe,
Damn...I sure hope that the good folks at Kershaw/ZT take notice!...You did an EXCELLENT job of shortening the full-sized ZT 0200!...You MUST be one hell of a GREAT jeweler!.:thumbup:.:thumbup:.
I wanted to show that "tooling up" for this would be a breeze,.....because you can use the same stainless blanks and just cut one end a bit different. Same with the blade.....
.............and THEY can do it before the blade is hardened!:grumpy:
.........BTW,...... i'd be willing to send it out to Kershaw as a prototype at no charge,......
........if they would send it back razor sharp! :D
Joe,
at first it looked a little castrated to me, but I think that's only because it's next to the regular. Wish I could go into a FrankenZT lab.... ;) Thanks for the pics!
I think that is awesome. They should put that into production. I am particularily fond of the butt end. Very unique and I bet very functional. Finally a place for those with large hands to put the pinky (on a short handle that is).
The shape of the handle was actually dictated more because i had to work around the holes placed in the steel liners to lighten them a bit, and i wanted to keep as much strength in the spring part of the liner also.... so i kept most all of the "meat" just past the hole that was there.
If i get a chance tonight i'll pull it apart again and take some picks of the bare liner,.....and lay the pieces removed next to them to show the cuts.
In hand the upper part with the screws fills my palm nicely, and when i curl my hand around it all 4 fingers are on the lower flat portion.
Larger hands may need to make use of the cutout,......
The more i fool with it,....i think this would make a great everyday working knife for guys opening boxes and such,......the stubbier blade looks just about right and won't alarm folks as much as the full grown model......
......ESPECIALLY when i get it sharpened up!
just wanna make sure you used proper breathing protection when you cut down that g-10, but that is an EXCELLENT looking knife. With that shortened blade, that lock has to be unbelievably strong
I have it on me as i write,.....but it will certainly be more useful with a nice edge on the front end. The original curved back part of the blade is still like a razor.
...........when i moved 2 years ago i lost all my sharpening supplies.
Hope to get them sortly to rectify the situation.
Are you ging to carry/try it out?
Yeah,....i improvised with a couple of layers of moist paper towels inside a mask,.......and held my breath a bit anyway between grinding to let the dust settle.
.....i bet it's nasty stuff to be grinding on full time!
Joe,
As I mentioned, you did an EXCELLENT job of turning the ZT 0200 into a "Mini" (that is on my short list of knives that I REALLY want), but how about a larger version of the ZT 0200...Maybe with a 5.3 inch long blade?.:D.:D.
Only problem with that is here in new york state anything carried concealed has to be 4" or under,.....so on my EDC in my pants i'd be illegal!:grumpy:
As long as i leave it hanging outside my pants,......i'm legal! :D:D:D
......let's get the "baby" done first,......and we'll talk! ;)
Joe,
