Hey, wait a minute!...I thought that I was the nice-looking mod.Awesome job Joe. That is one nice looking mod!! :thumbup:
Hey, wait a minute!...I thought that I was the nice-looking mod..
I am in love!!! HE HE!! That is a beauty!
joejeweler
What did you use to cut the blade and handle with because those are very clean cuts!
I think if you do it you'll be as limited as i was with the cut placement,.....because of the weight reducing holes already there.
There is room to remove the last offset/screw hole and you could then have a rounded end,.....but that would also shorten up the "meat" in the palm of the hand and a big handed guy like you would miss it. It surely wouldn't be as strong a package that way either,......with one set of offsets gone.
I suspect my "baby" is actually stronger in some ways,.......the shorter blade length equals a lower load on the pivot and liner lock,.....thru decreased leverage. And one thing that is not apparent in the photos i took is that the point is much more stout because the blade grind does not taper as it was originally.
A few days ago i picked up a "Smith" diamond stone sharpening system at my local sporting goods store. Although i would have prefered one of the 3 grit large round sharpeners better suited to the these knives,.....this was the best sharpener they had locally.
I'll get the round diamond one later anyway,......but as i was mainly trying to get an edge on just the front part of the blade (the recurve was still a razor!),.........i tried it. The original sharpening angle appeared steeper than i could reasonable go,.....probably is around 20 degrees. I chose the 25 degree angle on the front part of my "Mini" ZT 0200 because the remaining metal was thicker from my cuts,.....and i didn't want to have the greater loss of black coating i would have if i used the 20 degree setting with the sharpener.
I will tell you it's still plenty sharp for my needs,......as i cut up some re-inforced packaging tape this week at work, and the re-sharpened part zipped thru that like butter.
With the stouter point of mine i bet i could open a can of beans or soup in a pinch also!![]()
BTW,.....better get in a supply of those thin stone cutting discs,.....i broke about 20 doing the blade alone. (they ain't lying about the rockwell on these babies!) The liners and scales were a breeze however..................
Also,......even though by shortening the frame you lose the lanyard attachment holes,.......i figure if i ever decide i need a lanyard i can attach a cord one to the last set of offsets. There's plenty of clearence with blade tip in the closed position.
Naw...The way Joe did his is totally perfect...I'd have to (try) to do it the same style. I have a fairly large hand, so I wouldn't want to make the grip any shorter than Joe did, and I like the fact that the knife is still held-together with 4 screws (including the pivot). I also really like the way his shortened blade came out...Perfect...Short & stout.:thumbup:.:thumbup:.
Im broke through Christmas...way to many friends and family to get gifts for!!
I feel your pain. I have a long list of knives but being a single parent
of 2 kids...well.....they just come 1st. It's all in the giving. The knives
will still be there after the holidays are over.
Joe, are the clip screws just tapped into the overlays, or do they reach down into the liners. How hard would it be to convert that Baby to tip up carry?
Oh, PM sent...
