- Jan 27, 2006
I thought i'd post some pics of interest to show where the cutting was done,....and why. Here you can see the cut off pieces of the stainless steel liners and how they lined up originally. Note the cuts were made where they were because of the placement of the weight reducing holes already there.
........ the finished liners, with top half having scales attached because the pivit screw is really tight! It has to be carefully hammered out with a brass, nylon, or leather hammer over a supporting structure. I took it out once to do the cutdown..........
......... a close up view of the liner lock,.....note most all of the supporting steel behind the "spring" cut out was saved with the placement of my cut. I didn't want to weaken this area!
Here's the blade with the cut off section in approximate position of where it was cut from. This steel is HARD, and i used cutting discs made from corundum,.....same material as sapphire & ruby.
Voila,.....about an hour later and the blade was rough cut off. Frequent water dips kept it cool during cutting
Here's the "butt" side finished off area where the frame cuts were completed.
I have a size 10 ring finger,.....so i'm about a medium hand guy and this is how it now fits my hand for controlled cutting situations. I'm a "righty", but i was working the camera with that hand.....
You larger handed guys might have to make use of the cut out at the butt end.
Here's a tight grip with full finger wrap,.....for serious situations!
