I haven't touched it at all. I made that mistake with a 770cf once and it was never centered again. I'm not adverse to it, but I don't think it's something that can be fixed by taking it apart.We have one ZT0450G10 left in stock and I just checked it. It has no rattle. Just to be on the safe side I also checked a couple of 450s, 450CFs and 460s and none had any rattle at all.
In the past couple of months I probably took 15-20 of the 450G10s apart for anodizing and never once noticed an issue. Not sure what is rattling but it does sound strange. I am sure ZT will gladly fix it for you. If not and you want to send it to me I will be happy to check it out and see what I can do.
Just curious, have you taken it apart or changed anything on it?
Are you sure about the movement range of a couple of mm? That would be larger than the size of the detent hole.
Regardless, I would send it in for warranty service. You can call KAI but I am certain you will be told to send it in.
So based on this you send me your non-rattling one and i'll send you mine that rattles and moves and we'll both be ok?Quit shaking it and it will quit rattling.
Really helpful bung holeQuit shaking it and it will quit rattling.
Ummm...no. I can't agree with your treatment plan and I have to hope ZT wouldn't either. This knife doesn't function as designed and the OP is correct in wanting to make it right. I don't think you've really helped here and if I choose to ignore you, I won't be able to call you out the next time you don't help.I didn't attack anyone or call anyone names. I was quite sincere. The fact that the blade "rattles" when closed is entirely subjective and appears to have no effect on it's ability to function as a cutting instrument and or it's safe use as one.
If you don't care for my comment then ignore it.
All trolling aside, as I said I have the same problem . I have the full titanium version. What I also noticed is that I can see a part of the extent hole when the knife is opened. Then a a part is sticking out from under the scale. At 45 degrees opened, you can see almost the halve of it sticking out.
So I think in my case the detent hole is just too big.
Any news yet?
service can take up to 6 weeks but often doesnt take that long. not saying it wont, but it could be a lot sooner.It's in their hands now. They said it's not normal, and I sent it in. It could be as long as 6 weeks.
Any idea what the issue was? Just realized one of my limited ZT's has a rattle as well as feeling ''notchey'' while closing the blade. I'd prefer not to send it to the mothership.Thought I would report back on my ZT 0909 with the same issue. The knife was sent to KAI on Thu two weeks ago. Got it just a moment ago. The issue was fixed. It is now perfect in every aspect. Kudos to KAI for its excellent CS.![]()
