sharp_edge
- Jul 30, 2015
KAI did not say about the cause of the issue. Many here suspect the issue is due to an oversized detent hole, which makes sense to me but I am not 100% sure.
That would make sense that the detent ball is too small for the hole. Other than replacing the blade, can the detent ball be removed, a larger hole drilled and then a bigger detent ball put in?
Had this same problem on two out of three TILTs I've owned- it was the lanyard tube rattling around. Put some oil around the edges, tightened it up good and no more rattle. Blue loctite works also.![]()
now?Got mine back a couple days ago and its all better now. They did not say the problem, just that it was covered and fixed.
