- Aug 10, 2012
I preach constructive critiscm, this isn't one of those cases.......again.
So I got a 0560 in a trade recently. I have a 0550 and its a great knife. Problem is the 0560 is VERY hard to open. It's almost like it's locked closed. I can open it if I push fairly hard on the flipper but as you all know, the jimping is pretty aggressive. It sort of feels like a cheese grater when I open it with the flipper. So to the thumb studs I go. Right handed thumb stud opening is impossible. Trust me, I'm no wimp and I have only been able to do it 2 or three times that way. Left handed opening from the other thumb stud is a little easier but who cares? I'm not left handed. Only somewhat easy way to open it is pinch the blade with two fingers and pull it open. Kinda defeats the purpose of thumb studs and the flipper. The whole reason I wanted the 560 is the flipper. I have tried tightening and loosening the lock bar stop and the blade pivot screw. No help. Has anyone else dealt with this problem?
Next minor issue is the bar that stops the blade when opening (not sure what it's called) rattles. I thought tightening the pivot screw would stop that but nope. I have a Griptillian with the same issue but I didn't think ZT would allow this. Is it normal? My 550 doesn't rattle at all.
Thanks everyone in advance.
Thank you for all the responses. I have to say I am totally disappointed with this knife. I am NOT a newbie to high end folders. I saw that whole BS explanation from KAI that the thumb studs aren't thumb studs. So on all the other similar models they are thumb studs but on this model they aren't? I'm pretty sure they were intended as thumb studs as well as stops but after people complained, they decided to rename them. I'm sure most of you that say yours is possible to open with the studs are correct but believe me when I tell you mine is IMPOSSIBLE with the right hand holding stud. I can be holding the handles in my left hand with no pressure whatsoever and it will still not open.
As for the flipper with the jimping, sure I can find a way to flip it without cheese grating my finger but why should I need to? That jimping just shouldn't be there like that. It's a horrible design. If I wanted a folder that required skill and practice to learn to open safely, I would get a bali-song. If I want a nice flipper, I don't expect to have to learn how to use it.
In summary I think this is a terrible design with inherent flaws. I can't understand why they would change anything from the 550 model other than maybe size, flipper, and steel. That's really all they needed to do if they wanted another model. That's all I thought they changed with the models. But no.
