This is a good point, and if it works better for you because of that, then that's perfectly fine, but higher toughness to most people isn't that much of a difference, unless the difference in toughness is very significant, and between M390 and Elmax, it is not an incredibly drastic difference.
Also, Elmax's higher toughness is one of the reasons it's notably harder to sharpen than M390, and takes considerably longer to get to a screaming edge. M390 also has a better reaction to sharpening, and in my experience feels smoother against stone, without giving too much difficulty or requiring a lot of effort to sharpen from dull or to re-profile (your mileage may vary).
My guess is that they'll continue to use 23 degrees per side...I'll probably go with the M390CF, but Elmax and G10 would also be great. What I'm more interested in is the blade and edge geometry. If ZT takes the geometry down enough, this could be an awesome knife.
My internal debate between the two has been focused on the blade finish. I prefer stonewashed to the two tone with the high polished blade.
I use knives a lot at work for cardboard, zip ties, plastic binding strips, etc, so edge retention is a consideration but my 0566 and 0550 have been great, so I don't see a need to step up in steel.
It's a tough call. I think I'm leaning toward the standard.
Same here. I reprofile knives as soon as I do a few test cuts with the factory edge.Won't last long. My diamonds will have it down to 15ish in no time
Love the insights guys, I've decided on the 0562CF. I just can't justify passing up the M390 for Elmax...super stoked, now if it will just come out already!
I think you've made a good decision. As far as the handle material, normally I too would prefer G10 for many of the reasons you listed in our original post. However, having played with both versions at Blade Show (you can check out my Blade Show article in another thread) I can tell you that the G10 version does NOT provide significantly better traction as compared to the CF version. I was actually going to buy both versions and swap the scales, but I abandoned that idea after I handled them - the G10 version is quite slick with almost no texture on the G10.
I personally believe this knife will be one of ZT's biggest sellers EVER. That means it should be WELL supported by the community of knife modifiers who will hopefully make some nice grippy G10 scales available for the 0562 in the not too distant future.
To be honest, I don't care what profile they give the edge, it won't be acute enough and I can easily change it.
The problem will be the blade thickness at the edge. I reprofiled my ZT0560 to 15 dps, but the thick blade grind means the edge is 0.047 inches wide at the shoulders -- horrible blade geometry. By comparison, my Sebenza in S30V is 0.017 inches at the edge shoulder. The main reason I don't carry my 0560 is because I have other EDC blades that cut much more efficiently.
Does anyone make a current model, in stock knife in both Elmax and M390. Same blade profile, thickness and length? Fix of folder?
Is it difficult to get hands on an anticipated production blade like this if you dont preorder?
