ZT 0566 - Now: Flipperless, CF scale, drilled & lightened, improved pivot, & more
Ive searched the deepest corners of my brain to try and figure this out and avoid asking this question because I know I'll feel foolish when somebody tells me but with the emphasis being on shedding as much weight off the knife as possible what exactly is jb weld in the torsion bar cavity in favor of?
Because when you add the larger washers the one on the spring side hangs over the cavity and is not supported by anything. The original washers are different sizes, a large one on the lockbar side and a very small one on the spring side.
Hey Guys,
super thread!
I am from Austria. I modified everything like explained and i wanna thank you for the detailed informations. The only thing thats missing are bigger washers. Under the posted link i can find them in the knivemaker store but they are out of stock.
Anyone an idea how i can get them?
Its really hard having everything prepared, but not able to finish the knife....
Thanks a lot
Robert
Hey Guys,
super thread!
Thanks a lot
Robert
I remember reading on here that someone had simply asked ZT for a repair kit for this knife, and were sent both washers and the assist spring. Then you would have two larger washers. Not QUITE as large as the .53 dia. I used, but barely under .50 if I remember right... Or wait for more stock, or do a bit more searching. You love the difference, and the super smoothness, and having it built for the long haul... :-) Tks..
Hey Guys,
super thread!
Thanks a lot
Robert
Check through the washers they have for sale there is another set that is almost the same as those linked. I believe the size needed http://usaknifemaker.com/folding-kn...gs/washer-bronze-3-16-016-id-with-505-od.html 3/16 in dia .505 ext dia and 0.016 width.
These are the ones I used and they worked fine.
http://usaknifemaker.com/folding-knife-parts-c-30/washers-and-bushings/washer-bronze-3-16-015.html
They are 3/16 in dia 1/2 ext dia and 0.015 width.
I tried the request a replacement and never heard anything back.
I sent Zero Tolerance a request for washers. All i got was the clip???
I tried again and nothing happened.
i go with the washers jwhyte suggested.
thanks
