Pilot1
- Sep 24, 2005
Anyone ever hear a clicking noise on the close?
Is your blade centered? It may be hitting the side.
For the most part yeah. If does lean slightly towards the replacable scale side but not a whole lot.Is your blade centered? It may be hitting the side.
And what really drives me nuts is I can't replicate it every time. It seems random.
I've also noticed that if I try to use my left hand; my hand pushes the frame lock against the blade and I can't open the knife unless I release the pressure. But I imagine that's normal.
I'll try to take a photo. I also notice that the "shave" down the top of the blade ends in different spots?The torsion bar in mine clicks when shutting it when it gets about 3/4 way closed. Strange part is it used to click really long until I dropped it on a concrete floor at work one day. Barely noticeable now. If you remove the torsion bar it goes away, but mine didn't make the greatest manual due to a weak detent.
Post pics of the centering. When you said "click" I immediately thought you were referring to the detent engaging. I really hope that's not it........
Looks like it scraping the liner....
That was my first thought. I bought mine used here on the sales forum, and it quickly developed an off centered blade, and a little blade play. I sent it into ZT Warranty service, and it came back perfect. No charge for the service either. Mine was clicking when it hit the liner but it is fine now, and has been for a while.
Tightening the pivot solved those problems for me![]()
I may try these first. I would hate to send a knife back less than 3 days after owning it.Tightening the pivot solved those problems for me![]()
Also......Loctite!
Bingo.That would be the torsion bar from the speed safe assisted opening....you can open up the knife and repack the cavity the bar sits in with some grease and it will stop....
