ZT CTS204P weird
Just to make sure.
As noted above, a wire edge (or a foil burr) could feel very sharp due to its thin shape and often lingers on a sharpened edge. To test whether it is removed, I slide my edge on hard wood surface or slightly cut into a wine cork, and then check the edge under intense light (sun light). If I see reflections on portions of the edge, it indicates that there was a wire edge. You can also cut into a piece of Amazon-type cardboard shallow (1" deep with light pressure) and inspect the same way.
Skip this if you already know.
Miso
^you can also feel a wire edge with your fingernail. once bent one way or the other from cutting use it's easy to see it catch your fingernail. be careful though, as you don't want to slice your fingers off.
