- May 11, 2018
ZT Zero Tolerance 0095S90BLK or Zero Tolerance Sinkevich 0452I can only afford one which one would you buy? The Good the Bad and the Ugly??
I love my 0095 Tiger Stripe S90V, so naturally my vote is for the 0095.ZT Zero Tolerance 0095S90BLK or Zero Tolerance Sinkevich 0452I can only afford one which one would you buy? The Good the Bad and the Ugly??
0452 hands down.
Why 0452? would you be kind enough to share with me please. Thanks sooo much0452 hands down.
The black coating seems easily scratched or delicate any thoughts?I love my 0095 Tiger Stripe S90V, so naturally my vote is for the 0095.
Blade length to weight ratio is amazing on the 0452. It packs a long blade into a compact thin package that is easily carried unobtrusively. The longer blade is more suited to food prep and has excellent cutting ability (especially once reprofiled) which translates to ease of use.Why 0452? would you be kind enough to share with me please. Thanks sooo much
And Why?
Because the 452 has one of the best actions on any ZT. Also it is exceptionally light for its long blade length. Despite being longer the 0452 is much thinner and more comfortable in pocket than other wider ZTs imho.
Also most ZTs that have a carbon fiber or g10 front scale on one side have a stainless steel liner under that composite scale. The 0452 does not have this liner. Personally I love that about it as it contributes to a thinner lighter knife. Since pocket knives spend most their time in pocket it is very important to me how comfortable they are in this position. I don’t know if you will carry it in a purse though in which case pocketability will be less important.
Also the 0452 is quite a big knife. Are you sure you want a knife this big? Check out the ZT 0450 for a smaller version of this same knife which is more practical for carrying around every day.
Is you handle BLACK? Im looking for feedback if it scratches easily because it looks sooo smooth black on it?Between the two knives, I use my 0095 more than my 0452. Neither is a bad or wrong choice.
Hi! ^_^See can you see where my knife is located?
hi back heheHi! ^_^
Flipped in store was easy on the eyes and fingers but your right. It was more of a steel and keeping the looks long term which would out performI don't know how much experience you have with flippers, but the one thing I would note about the 0452 is on long, slim blades like that it can be easy to rest your fingers on the lockbar and push in the detent when holding it. That can make it next to impossible to actually flip the thing, but it's easy to avoid once you're used to it.
