I don't think DLC is that tough. My friend was playing with another friend's DLC coated Blur and cut through a cola can for fun and it scuffed up the finish pretty bad. He felt bad as he should've. Aluminum is soft!
I would have to agree with you. The hardness of the actual material is usually used as a tasty data point in which to appeal to consumers. "Its hard as a DIAMOND!" well yeah the actual particles are very hard. But the bonding is where it gets tricky. If there is contaminants or just other factors that inhibit the bond then it really wont matter how hard the particles are. I can glue diamonds to my car with elmers. But that doesnt mean that I cant take them off with a shamwow just because the diamonds are harder than my piece of cloth. The bond is everything.I don't think DLC is that tough. My friend was playing with another friend's DLC coated Blur and cut through a cola can for fun and it scuffed up the finish pretty bad. He felt bad as he should've. Aluminum is soft!
I'll bet you $10 that it'll come off. DLC is tougher than aluminum. The scratches is actually the coke can getting rubbed off on the DLC, not the other way around.
Well thats half true. The material used (DLC) is very hard. But even though the material itself is hard it sometimes doesnt stick as well as people would hope so it can be scratched off due to the bonding process not always being nominal. So even though the aluminum didnt actually scratch the dlc, it could have removed it if the bonding was poor. Ive had numerous knives with DLC that scratch in very short order. There is this myth in the world that softer materials cant damage materials that are harder than they are. This just isnt the case. It just takes more effort for them to do so.
Hum. I hadn't considered that. We gave it a good hand rub but the stuff didn't come off. *shrug*
I'm confused now. So softer materials can damage and scratch harder materials? So then aluminum anodization (Type II and III) being a different process than DLC filming is really basically the same.
Wow...
Wow...
With that theory, I'm going to go scratch a diamond with some talc.(softest mineral on earth)
Well something to think about in my industry its not uncommon to have rubber completely rub thru steel so yes in some circumstances a softer material can do damage to a harder material. That being said I agree the dlc is probably stained with aluminum and will clean up fine .
I'll still take the bet.
