- Oct 20, 2004
The center line of the blade, drawn from the point to the ricasso (independent of the angle at which the handle might meet the blade).
Ok now the why.
Why is this axis neutral?
No, I am talking about the secondary bevel, i.e. the cutting edge. The primary grind is the wide one that goes from the flat part near the spine down to the secondary bevel.Are you talking about the primary edge angle?
Hardly any knives are "zero bevel." Notable examples are the custom Emersons, where the primary grind is the cutting edge. Most knives have a secondary bevel that takes the super-acute angle that would be formed by the primary grind and brings it down to something that will last longer and be easier to maintain/repair. In the case of a really thick blade with a short primary grind, the secondary bevel must be pretty wide to get any sort of useful cutting edge. That's why the wider blades of the ZT (and others) lend themselves to better edge geometry per thickness: they utilize more distance to go from thick to thin, resulting in narrower angles and the possibility of a shorter secondary bevel.
Custom Emersons are indeed "zero bevel," which is why I used them as an example. Look it up. I am aware that the production versions are chisel-ground, and that is irrelevant.The possibility of a shorter secondary bevel, not the presence of a shorter (or more acute) secondary bevel. That really depends on the thickness of the blade itself, not the width of the blade.
I assumed you were talking about the primary bevel because yes, with a wider blade that tapers from a certain width to zero (assume a scandi grind for a minute) will have a more acute angle then a thinner (not as wide) blade.
Emersons aren't zero bevel, they are chisel ground. There are two bevels on the blade.
Yes, possibility of a shorter secondary bevel. That's what I've been saying. To illustrate this, I used the example of a knife with zero secondary bevel, which is (of course) the smallest secondary bevel possible... zero.
And, the whole point is this:
You have two pieces of steel, one being 1/8" thick and 1" wide, and the other being 1/8" thick and 1.5" wide. If you grind them to a sharp edge, while still maintaining the maximum width of each, and starting at the spine (or at least at the same distance from it), the wider piece will have a more acute angle at the edge.
Period.
It's simple geometry.
Custom Emersons can be zero.
So can convex edges.
I think both sides are talking about the same thing: you can have a blade with a thick spine but a thin (acute) edge when the blade is wide.
A problem that has plagued humanity since prehistory.but it doesn't seem to matter because nobody is listening to each other.
Ok now the why.
I'm going to draw up something to better illustrate what I'm talking about.
What is a neutral axis? Does my knife have one?
Seriously, what is a knife's neutral axis???
