- Oct 27, 2010
Whatever fits and balances the gun best.
-X
-X
what's the best carbine stock for accuracy
How do you like that Luth-AR MBA stock? I've been thinking of picking one up due to the savings over the Magpul PRS.
-Xander
How wide is the cheek weld, side to side? I don't like a real wide one or one at a shallow slope. The narrower (to a point) the better for me. I use my cheek bone as a reference point in my hold, so I don't put a ton of pressure on it.
I wish I could find one local to shoulder.
-X
Anything up close, especially of the split ring. An ADM mount without the hollow ring just throws me off visually so anything of the solid ring.
Is that a 3" offset or a 2"?
-X
Which ACOG is that? I'm going to put one on a similar rifle and I can't figure out which would be closer for a 16" 308... ...the 308 ballistic reticle or the 5.56. From what I understand both the 308 and 5.56 are calibrated to a 20" barrel. From what I can figure 308 from a 16" barrel is right in between the two for drop once you get out a ways.
I'm thinking a TA 11 with a green horseshoe but the chevron looks okay too.
The big difference between the AR15 and a bolt gun is end user being able to customize. Swapping barrels, mags, triggers, stocks is so much easier with good results. Even on Savage bolt actions swapping barrels isn't quite as simple. But, bolt actions are capable of much higher degree of accuracy. Just go look around for Rem 700 parts, there is enough to make your head spin as well.
-Xander
Well, a chamber for an auto loader can never be as accurate as a bolt guns. Even "match" grade autos compared to hunter class F/rifles. If any auto loader was as accurate as a bolt gun you would see many more on the line at comps in classes other than service rifle.
1/2 MOA is damn good for even a billet matched set AR with an air guaged barrel and good trigger. Most stock bolt rifles come that way or close to it.
-X
I think M67 was misinterpreting my remarks as disparaging. Not at all....I think our ARs are perfect for the purpose, and for many other purposes as well.
Just commenting on all the stuff available. Applies to many other fields as well. I like "primitive" archery; I make longbows. However, I got a catalogue from a big archery supplier for some bowstring material, and about 2/3rds the catalogue was filled with accessory "bits" for various compound bows. Aftermarket items to improve and customize.
