J. Doyle
- Feb 17, 2008
I'm not 100% sure what you're driving at here.1. I can only work with the information you posted not what your perceived intentions or thoughts are.
2. Normalizing is a part of thermal cycling. Refining grains and carbides doesn't change the fact that austenitizing temperature is the most significant factor for differences in hardness, toughness, strength, etc.
3. Control at a specific temperature doesn't change the fact that different Austenitizing temperatures are what is controlling retained austenite the most followed by cold treatment.
4. It's not about the small change in hardness as much as it's about removing undesirable features in the microstructure.
That wasn't any kind of secret heat treat that was just showing the difference Cryogenics makes.
If there's that much of a change in hardness than there is a significant amount of retained austenite that's being converted with the cold treatment.
@sodak seems to notice a difference
In my experience, the edge has better resistance to deformation and better edge taking and deburring.
All I initially said was 66 was "pretty much" the as quenched hardness limit of 1095. Which it is. Yes, as you and I have both attested to, another point or two CAN be gained under ideal circumstances.
You seem to be talking to me as if I have some issue with my heat treating process/1095 (I don't) and that I reached out to you for help (I didn't) and that I'm disputing what you're saying (I'm not).
I actually have a very good understanding of heat treating and very good control of my process, including specific numbers and lots of testing of various types. I assure you....I don't have a RA problem.....I'm not sure why that is coming up?
Sounds like you have a good understanding of heat treating too. Congrats. Hopefully you're up to your neck in orders.
