Yeah obviously it's all down to what you're working with and how/why.
I honestly think 1095 has lost a lot of it's good rep by all the excessively soft, thick-edged, beater production knives, to the point that lots of people don't like it and think it's a crap performing steel. The reality is, it can be near the king of "simple high carbon" steel (the exception being Hitachi White or certain batches of W2, which are specialty and much rarer) if good stock with refined grain and the appropriate geometry. That, and it's application as a near optimal cheap spring, is why it became so ubiquitous in the market initially, decades ago.
I surface grind anything I work regardless, so no amount of clean stock is saving me time there, as an example, but I can see how it would for different methods and equipment, definitely. That of course is also one of the reasons industry utilizes 1095 though, you can get it from thousands of suppliers, in any configuration you could ever want, for less than half the price of 15n20. Of course that requires you to have an idea who to deal with, and meet minimums, etc. So for the average maker, may not hold much value or appeal...
Ultimately it's highly circumstantial, preferential, and even intuitive why we use what we use. Certainly nothing wrong with any of the steels any of us might consider.
Funny to see 52100 mentioned, because it's a steel I have a high regard for, but I also think it's one of the most potentially complicated steels to really optimize. It's a bitch to forge, hell on tooling and consumables, and a bitch to hand finish. It has a massively wide potential range of performance based on HT, outside of industry baselines. i.e. it can be utterly mediocre, or some of the most insane performance ever witnessed. I have great respect for this steel because I've seen it do shit I've never seen done with other alloys, but I also know from the little I've worked with it, that I haven't begun to truly understand the metallurgical complexities to really maximize it's potential.
It's much like A2 and D2 in my mind. Where looking at the results somebody like Nathan Carothers can get with extensive experimentation, understanding, and grueling refrinement, make it obvious the potential, yet then seeing "by the numbers" examples inspire little, if any faith in it.
The one thing about 1095, aside from being less consistent the QC department compared say W1, W2 and the Hitachi and B-U steels, is that it is actually easier to get "wrong" in the HT that say 1084/85 or 15N20 because it is a very shallow hardening hypereutectoid steel. As you point out, it is cheap to acquire, but does not respond well to less than ideal HT regimens, especially for knives. To my mind, if these knife companies are looking for "tough' cheap blades, 5160 would be a better inexpensive and readily available option, although you can have similar QC issues.
I agree wholeheartedly about the HT issue. It's not that it's tricky steel to HT, it's just that you need a fast process, it's easy for people to screw up, however in regards to the production knives, I think it's really almost entirely the issue of targeting excessively low hardness, in pursuit of toughness, to accommodate the crazy warranties, as I mentioned above. I say this because my impression is that most of these companies are sourcing HT, presumably by reputable outfits, and honestly, any heat treating company can HT 1095 with expected results, there's not a lot of room to play with 1095's HT regime. However I don't think there's ever a situation in which 1095 is a good steel choice, where it should be less than 60 RC. If you're going lower, needing toughness, definitely 5160 or something like that would be a much better choice, and of course, 15n20, even at 60 where you're needing something tougher. Although that's just my opinion, and I'm sure someone will disagree.
However in regard to the QC aspect of the steel itself, I'll say that I've gotten 1095 from numerous providers, always with certs, and the quality has been very consistent. Not sure if there were some bad batches floating about or something, and getting mystery steel from Admiral not-withstanding, I'd argue that it's much less likely to get wide variation from 1095 than any of the W steels, simply look at the allowable spec ranges. W1 and W2 have a HUGE range of allowable carbon content for example, where as 1095 has a pretty narrow band by AISI and SAE specs.
W2 gets a lot of love around here, and rightly so, it's my favorite steel, but in my case, that's specific to a few certain melts of the old Tremblay stock, i.e. Don Hanson's big rounds, and some of the small rounds and large drops. In each of these from the same source though, the chemical comp shows some pretty heavy swings. The stuff Aldo has currently (and even the first batch he had that so many had problems with), has a different spec. All well outside the variation I've seen from the handful of cert sheets I've seen on 1095 from different suppliers in the past few years.
I actually always cringe when I see someone recommending W1 to anybody here, since it can be so different batch to batch or supplier to supplier, and the likeliness of getting optimal results from following industry standard HT for it, is low. Of course if you found a good batch, dialed in the HT, and bought enough of it to last you a lifetime, you could get consistently great results. I don't think anybody should be using it as a one-off though, 1095, from almost any supplier, should offer better results with "by-the-book" HT.
I had avoided mentioning any specific companies and I will still not mention them by name, but in case you are interested, I will give you a hint. Are you familiar with the company that "Spec ops prefer?" Google their shop tour video and take a look at the HT process they show. You might be a tad surprised. Contrast that with the shop tour video from R Murphy Knives who sell their "carbon steel" knives at a significantly lower price point.I agree wholeheartedly about the HT issue. It's not that it's tricky steel to HT, it's just that you need a fast process, it's easy for people to screw up, however in regards to the production knives, I think it's really almost entirely the issue of targeting excessively low hardness, in pursuit of toughness, to accommodate the crazy warranties, as I mentioned above. I say this because my impression is that most of these companies are sourcing HT, presumably by reputable outfits
Aldo's current W2 for the last 4 years has been based on the HansonIII steel. There are minor differences in the elements, but it's quite similar. I sent a bit of Aldo's stock to Don, and he got Rc67 instead of Rc68. No one has complained with the W2 knives I make, and I did a lot of experimenting to dial in the heat treat. I would love to get my hands on some of Don's W2, but no one is selling.
1095 is a fine steel. It takes as much care to heat treat properly as W2 does, but it doesn't perform as well. O1, 52100, W2 all outperform it.
I use 1095 to give kitchen knife users an option with a hamon that is cheaper than W2.
I just want to add, and something I'm not sure I've mentioned, but I think is a big factor. Lately I've seen a desire here to increase the "brand value" of 15n20, I think because of the ubiquity of it among makers, and especially that we can get it second hand sometimes for next to nothing, however, I'm not personally seeing any indication in the market that it has any real brand value higher than 1095, certainly not more than 1084.
It doesn't have a bad rep, but it hasn't gained any wide-spread appeal yet either. 1095 is actually losing some ground in this department, and I'm seeing a gain with 15n20, so at some point it may become much more widely regarded as being something more than "great for damascus", but as you guys have indicated, that's going to pretty much require the availability of thicker stock.
Thing is, the intended target market for 15n20 didn't ever require thicker stock, and the entirety of the custom knife market, is a drop in the bucket comparatively.Also unfortunately, the sole provider of this material, is a somewhat gentrified, and seemingly traditional international corporation that is much more interested in securing large volume individual orders, than lots of smaller orders.
Thus begs the question, does 15n20 have the "brand" potential to out-value similar options, if it became available in more configurations? It's certainly possible, and maybe that's the ultimate point of this thread?
I think this is the biggest handicap we have when looking for blade steel. Now if one has spare cash and the right machines, Bestar (https://www.bestar-steel.com/company/presentation/) imports all sorts of interesting steels BE2419 & BE2519 are similar to O7 and Blue#2 BE86=8670 and might be what AKS is importing. BE5634=15N20 BE2235=80CrV2Thing is, the intended target market for 15n20 didn't ever require thicker stock, and the entirety of the custom knife market, is a drop in the bucket comparatively.Also unfortunately, the sole provider of this material, is a somewhat gentrified, and seemingly traditional international corporation that is much more interested in securing large volume individual orders, than lots of smaller orders.
1.2419 is 105WCr6, 1.2519 is 110WCrV5, so these steels are very similar in composition. BUT only BE2419 and BE2519 are available for sale in the US at sorta reasonable prices. I guess there is not enough demand for NJSteel or AKS to carry them. Bestar (770) 801-8855 will sell single sheets from their warehouse in Atlanta. the last quote on 1.2419 I got was 335$ for a sheet 2.5 x 210 x 1820mm.I think O7 and Blue#2 are similar to 115w8. I could be wrong though.
115w8 is my favorite steel.
Very thankful for this thread and all of the great conversation in it. I have been trying to choose what steel to order for my first big order from NJ Steel Baron and had really settled on 1084, but unfortunately they have been out of stock in the .156 stock I want. I actually wanted thinner than .156 but that was their thinnest and I don't have a surface grinder (yet). Anyway, looking at his selection of 15N20... available in stock all the way up to .130! This is exactly what I'm looking for, and it's basically the same exact cost as the 1084 (I understand the 1084 stock was thicker, so the 15n20 is more $ for the steel). But at the same "cost per 48 inch bar" I am fine with this! I am putting in my order today!!! Hope ya'll dont mind if I ask some steel specific questions here... Excited to see how the patina compares to 1095 which I have a lot of experience using in the kitchen and field.
Very weird! When I go to NJSB and click the 1084, the dropdown menu only shows it in thicknesses down to .156... how do you select .125? I will look at AKS now... i might try a few different steels and also need some micarta and pins. I don't see any of that other stuff on Aldo's site.Aldo has 1084 .125 in stock.
Alpha knife supply also has 1084 now.
You'll save some on shipping with AKS.
