Riiiiiiiight. That must be why there are so many videos of Fehrman's CPM 3V knives shattering into a million pieces under the slightest lateral strain.
Can you post links to videos of them being laterally torqued and returning to true?
If it's not truly solid, what is it?
Any examples of these failures and figures?
Here is ingot steel NOT failing or micro-chipping:
http://www.scrapyardknives.com/ubbthreads/showflat.php?Cat=0&Number=202608&page=38&fpart=1&vc=1
http://www.scrapyardknives.com/ubbthreads/showflat.php?Cat=0&Number=451415&page=0&fpart=1&vc=1&nt=3
Any examples of powder steel undergoing the same, with similar results?
Tempering has much more to do with it than just hardness, take 2 blades, same steel, but tempered differently, they will react differently.
Hardness can effect the steel, but that's not all of it.
There isn't just one fit all answer when talking about steels.
Dude, seriously... Assuming the new edge bevel is straight and not convex, you look at the height of it. You then look at the same model of knife that you own and measure the thickness of the blade at that height. Do a little math and that would tell you roughly what the angle is just by looking at it from the side. It's called "basic trigonometry".
is this referring to something in particular? and testing knives is not testing steel, stress risers, bad grinds, poor heat treat, different profiles, there's too much variability to make a claim about a steel based on the test of an individual knife. That's why tests like charpy and izod exist.For the ones brave enough to test claims of Superman-like toughness, when the knives fail well below published figures, they are blasted for their efforts.
Depends on the alloys. Increasing tempering temp can cause secondary hardening in some, with a better hardness/toughness balance. This means there is not a simple inverse relationship between hardness and toughness. There is also tempering embrittlement to consider. You reduce the toughness of a steel as you increase tempering temp (decrease hardness) until you pass the embrittlement zone. And there's just the difference between alloys. Taking 1095 up to 64 causes a considerable drop in toughness, while many HSS are designed for that to be their working range and have higher impact numbers. Ingot D2 is one third as tough as CPM-3V with both around 60 Rc.It is in fact true.
Can you provide a link, or elaborate on that "most basic heat treatment information" which shows this not to be the case?
you ignore everyone's personal experiences with real life use and rank steels based on your own "test show", so I don't know what you're criticizing.So again here we have simple try to find excuse for difference between real life experience and "test show", this is actually part of the show naturally.
Well, what leads you to this assumption? Now assume that it is curved and if you look at reflection you may pretty much see that it is not straight. You actually may see that at the very edge it bends in quite radically and so here we have pretty different case.
Thanks, Vassili.
What "leads me to this assumption" is that it was already said that he sharpened it with an EdgePro, which is a jigged, flat-stone system. Those systems create flat bevels. Obviously the illusion of a curve to the bevel was your eyes playing "test show" on you.
What do I not know? I know that when I want to check the edge angle on my knives, I use my laser goniometer. Before that, I measured with calipers and did the calculations. I have several printed books and gigs of reference materials on steel composition, alloy effects on properties, heat treatment, test papers from several sources that were published for peer review covering cutting of processed food, meat, vegetable matter, lumber, edge life, effects on cutting forces caused by level of edge polish, edge angle, slicing speed, and push cutting force. I have done informal cutting tests of cardboard, pine, and manila rope. I've looked at my own edges at magnification from 10x to 400x.Well, ok - you do not know, thanks for sharing this.
Did you done any testing yet to talk about steels?
Thanks, Vassili.
Do I have any formal testing? No, but the blanks have been cut and will go out for heat treat. That is all I'm going to say about it until the testing has been performed. Expect a rather lengthy post/blog entry when it is finished.
With plenty of pictures!
