I was working in the shop today fiddling with my HT oven a decided to normalize some blades I was working on, one of which was a hunter I will be doing a full flat grind on using my usual method: Files. Well heres a tip, keep the teeth clean by banging the files edge on a wooden surface to clear chips, it helps for a cleaner cut without marring the surface of the work It also prolings the life of your file. I triued chalk for this, but wasn't satisfied with the results, though IIRC WD-40 worked great to ease the cutting. I find keeping the file free from debris to be especially important when draw filing. Also when draw filing make sure to pressure the entire face of the file evenly, as opposed to one side more than the other like you can do when hand sanding a plunge line. Other wise the teeth will dig in and you'll be left with some nice deep gouges that will be tough to remove.
