Reasonable people can disagree about what constitutes redundancy, where to draw the line between preparedness and paranoia, and so on. There's no need to get heated about it.
Most of us plan a degree of redundancy into our wilderness preparations, in terms of gear and in terms of skills. One rarely sees a PSK or woods kit with only one cutting edge or a single means of fire-starting, for example.
In terms of where to draw the line, I think that everyone is different, and that planning needs to take into account skills, knowledge of the area in which one is travelling, and what one considers to be the threshold between packing responsibly and carrying too much gear. Your mileage may vary.
For me, I like to think about redundancy in terms of tasks, as opposed to gear. This means having more than one way to make fire, cut wood, build a shelter, light the way, handle an injury, navigate, and so on. In some cases, this translates into carrying backup gear (a PSK and a diversified fire kit, for example). In other cases, I'm content to keep my gear to a minimum.
As for mindsets, again, to each his own. For me, the wilderness is a place to be enjoyed and respected, and while I take steps to be what I would call reasonably prepared, I do not view every excursion as a potential SHTF situation. Nor am I particularly concerned about self defence and protection when I'm in the bush. If that's your thing, then bully for you.
All the best,
- Mike
some people don't choose to live in that kind of mindset, some people end up with that kind of mindset because of what they have experienced, lived or survived through. it is not a choice, it is the way it is for some people, and you just have to do what you can to keep from ripping out of your skin. sometimes doing what you can, may seem 'odd', or 'foolish' to people but that is because they just don't understand.
Ok so two is one. But what if your backup breaks or is inoperable and you don't know it until your primary fails? Then what?
If you have seen many of CM post, you would understand why I dont take it as an exaggeration....
a tinfoil hat can be a tremedously useful tool. if you have to travel through crowds and you would like to be left alone, or just to have people stay away, throw on a good ole' tinfoil hat(mine is a pirate hat). it is like moses walking up to the sea, a paths appears where there once was none. calling someone a nutjob, plz correct me if i am wrong(i looked through the rules i could find) belongs in w&c.
Ok so two is one. But what if your backup breaks or is inoperable and you don't know it until your primary fails? Then what? Because of that you should carry a thousand of everything. The likelyhood of all one thousand of your whatevers breaking all at once is very small. Also, one never knows when you'll need a spare penguin. Or door. Or canoe. What would you do if you found your primary penguin had died? I'm sure you don't want to find out. So just to be safe, to be PREPARED, one should carry a thousand of EVERYTHING ON EARTH.
Just
In
Case.
:jerkit:
No personal attacks allowed here guys. Infractions given to responsible parties. This post is over in my opinion. Choose your words carefully.
I think you're stuck in "look at me" mode.
