Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I'm not following your wiring? Eiter the motor or the VFD has to be on the center terminals. Can y ou post the wiring diagram that came with the switch.
Basic wiring of a three-phase reversing switch:
The numbers used below are for example and may not match your switch. Use the switch contact diagram to wire properly!
You put the wires from the VFD on the center set of terminals. Let's call them 4-5-6)
You put the motor wires on one of the end sets of terminals (call them 1-2-3)
You put jumper wires as follows - 1 to 4; 2 to 6; 3 to 5. This will reverse the direction of the motor.
With the switch in the "1" position, the motor runs one direction; in the "2" position it is reversed. In the "0" position it does not run.
