You're correct; it is going to be some version of off-whitish/light color.
Will the proposed Micarta be a solid resin, or will it be combined with layered fabric (linen)?
I may be wrong, but my understanding is all micarta is a form of layered epoxied material; choices being paper, linen, and canvas. Without this substrate it would be akin to an acrylic.
You are right. "Micarta" is, by definition, layers of fabric bonded together with resin. The original resin was phenolic. Today it can be any of a number of resins, but the most common ones are epoxy and phenolic.
Congress Jack-Blade Forums 1095 Carbon Steel
Size 3.5" - 4"
Sheepsfoot primary blade behind pen secondary blade
Long pull on primary blade
Standard nail mark on secondary blade
Nail marks to be on shield side of both blades set to not
interfere with each other
Blade Forums tang stamp - will have to have new one
made to fit
2013 stamped on tang
Half stops on both blades
Main blade as long as possible but no longer than 3"
Extended spring to close secondary blade channel
Satin finish on blades
Cut swedge on primary blade
Drawn swedge on secondary blade
Bolster and pins to be nickel silver
Square style bolster on both ends
Rattail (one medium thick groove per bolster)
Fine grained paper or linen micarta off white/ivory color
Pinned shield to be long, centered and running parallel to
long axis of knife
No etches
No Serial Numbers
