Mink
- Apr 2, 2012
That looks good OH :thumbup:
I would second that pattern. Great looking bone on it as well.
Of course, the Case canoe is single spring. But we've had a canoe for a forum knife, if my memory is correct.
Have you guys ever thought of having a forum contest to design your own pattern? Based on a traditional but with a unique style.
My mistake. An old Case canoe from the '70s or before was single spring, and I thought they were all like that. Apparently they stopped making 'em single springs some time in the '80s.
I like when the blades are ground to fit, shows craftsmanship. But I also hate blade rub. Knives as expensive as the Presidential should have no rub.I'm not a fan of the 2 bladed single spring. The Northwoods Presidential I had (and the other one I still have) suffered from bad blade rub. Not just a little, more to the point of catching and not fully snapping closed. The fix is to either grind the blades so they're offset, krink the offset, or shorten the blades so they don't hit. None of those options sound too good, I would just rather have 2 springs.
Still, I'm really anxious to see what the manufacturers offer up. CS already set the bar pretty high!
..... I don't think I was bashing anyone or anything. I just think that blade rub should be eliminated in a high price knife, as it is with my two blade single spring GECs. For the same materials, other than covers, from the same company for considerably less. So if we have a two blade single spring knife I would expect it to not have blade rub if it's close to $100. Relevant to the discussion of the 2015 forum knife because I would be disappointed to receive a knife with considerable blade rub if we go with a single spring two bladed knife.This is neither here nor there, but Knivesshipfree was very clear and upfront about the potential blade rub. So much so tha okbohn made a video explaining it. It was a known fact before anyone purchased the knife if you took the time to watch the short video. Derrick stated in the video that it would have cost a LOT more to eliminate all blade rub. So apparently in his opinion, for the price . . . the blade rub was acceptable.
Everyone has their own opinion. If you want to go that thin, the blade rub is probable. If you don't mind the extra thickness . . . blade rub problem is a non-issue. Let's focus on the forum knife and not turn this into a bash fest! Especially since the maker being talked about doesn't even have a stick in this fire. If Northwoods were a candidate for making our knife this year, then this would be worthy of our discussion.
Here are some pics of single springers. Note, several of these have a little blade rub, which is typical of the breed. They ground them thin to be superior slicers/cutters.
The reasons for including them in my collection are many - here are a few:
-They are light and easy to carry
-They are harder to make (the wow! factor)
-They often have superior finishing
-with the typically thinner blades, they cut!
-you have a spare blade, but not too many of them.
-you have to admit, they are lookers!!
