2022 GEC Bayou Trapper #88 Thread
I got my gator in today to complete the quartet and can now flesh out my thoughts on the pattern a bit more.
For me, despite its quirks, the 88 has been a much anticipated release for me. With my present and keen interest in wharncliffe trappers and my fondness for both the Lambsfoot blade and the Sowbelly frame, it would have been silly for me to scoff at this latest offering from GEC. For all its stated strangeness, I've seen far more outlandish configurations in traditional patterns that date clear back to the 1800s so I won't be convinced that this is anything too out of the ordinary and I applaud Bill and his crew for executing this concept so brilliantly.
(As an aside, I have very much enjoyed the musical evocations that these knives have brought - Iron Maiden's "Aces High" and Creedence Clearwater Revival's "Born on the Bayou".)
I was immediately struck by how this knife met and even exceeded my hopes and expectations. Having a well established preference for two-bladed knives, this one pairs a brilliantly and elegantly designed clip blade with the most utilitarian of all straight edged blades and packed them into one of the more ergonomically superior frames in existence. How can I not love this knife? Plus, with a very fine effort from GEC on the build quality, I am rather hard pressed to find anything to nitpick. As I mentioned before, I haven't pocketed another knife since I received my Ace.
Should GEC opt to run a single blade clip version of this knife, I think folks would be very, very pleased. If folks have blade deletes in their forecast, despite my fondness for the Lambsfoot, the clip is the one that you should retain. It is sinuous, graceful, and wickedly elegant - it flows with the frame perfectly.
For fans of the Sowbelly, you will find that this 88 runs on the larger side. Comparing it to the Queen-made Winchester, you can see the obvious similarities - it is just oversized.
One of my regular users that I find most comparable in size and utility is my 82 Dixie Stockman. I think the 88 to be more robust overall but I'd say pocketability and efficiency run in the 82's favor.
This gives you some idea of how the blade might be oriented in hand when using either option.
My example of Ironwood is quite pleasing and it thrills me to death that GEC opted to take the extra care to polish it out versus their typical and uninteresting satin finish from past runs.
Some additional thoughts:
I thought this run encompassed a lot of thought and care on GEC's part. A nice and concise selection of handle materials (only thing missing really was a Stag interpretation), excellent shield choices (seriously, I love that Ace shield and I don't hate the Gator), and an innovative and utilitarian design concept that was executed brilliantly. If GEC continues this trend with future runs, I think we are in for some exciting releases.
If it hasn't been apparent yet, I am very pleased with this run - well done, GEC.
Ironwood lotto winner! Wow. Also and excellent review.
You have a very sharp eye Joshua JTB_5 JTB_5 . I put mine to the rods yesterday and thought I saw the same thing on all three of mine but blew it off but after reading your post, I checked mine on a straight edge and you are correct. All of the clip blades have a very slight recurve and all of the lambfoot blades have a very slight belly. Another trip to the rods has taken care of the matter.
Thanks! I've tried to follow Murray Carter's method as much as possible, which involves eyeballing the knife edge from six different angles. Also, using water stones might give a little more sight and feel feedback.
Decided to go ahead and try my luck at converting an 88 to a single blade lambsfoot. This is the first time I have disassembled a knife like this, so i recommend if you are squeamish, you may way to skip the following pictures...
Ok, let's get started with an Ace of Spades black micarta 88.
After studying the knife intently while drinking a glass of wine, I developed a plan to try and take the knife apart.
After that plan failed, I decided to try a different tactic using the razor blade, which actually worked out ok...
Now with the knife apart, I removed the spring and blade. The blade was actually a huge pain to remove, and required the pin be polished some, and some choice words to be said.
Finally, after much swearing and another glass of wine, the knife was ready for reassembly.
I was shocked that it actually went back together and the blade still moved.
View attachment 1811316View attachment 1811317
Still needs some polishing and clean up, but amazingly the blade works, and the action is as smooth as it was to start. Pull is very nice, and I now have the single blade lambsfoot 88 I have been thinking about. Also learned quite a bit about how these knives are put together.
Wine?
I would be drinking bourbon or rum straight from the bottle.
Well done, sir. The single blade lambsfoot looks fantastic.
Fantastic! That’s exactly what I want to have done. Well done!
Congrats on getting all four, and thank you for the thoughtful review. I had the choice of one out of four, and it wasn't an easy decision.
Very brave of you. I generally prefer multi-bladed traditionals, but I'll bet that single lambsfoot is an ergonomic dream.
Also, thanks for those photos of the partially disassembled knives. It gives me an idea of how much clearance there may be, if I want to file the kick and lower a blade.
My Bayou Trapper is at the post office box, where I can't get to it until Monday, and I dreamed of alligators in the city last night. 🐊
Very nice writeup Dylan........ The knife shape reminds me of French Curve templates I used in an earlier life when I did cabinet making..... Smooth, sweeping curves that invite the eye to explore.......
Also, a nod to the cutler that does the edge grind..... To follow the edge and maintain the geometry by free handing it requires oodles of practice and great muscle memory.... The edge might not be razor sharp, but the geometry is beautiful!!.... I wish I could do half as well😃
