Very impressive, are you willing to share your heat treat process?
1550F 10 minutes air cool
1400F 12 minutes quench in fast oil
1200F 1.30 hours air cool
1475F 10 minutes quench in fast oil
Double tempering at 350-375F for one hour each.
If you are referring to me, the answer is no, we do not supply GFS.You guys supply GFS who I get my stock from right?
Thanks Chuck.If you are referring to me, the answer is no, we do not supply GFS.
Chuck
Its too easy to put too much carbon in solution with 26c3 without temperature control. if you put too much carbon in solution the knife is going to be junk regardless of the hardness.Does anyone successfully heat treat 26c3 in a forge? I UNDERSTAND A KILN IS BETTER. But is this like 01 where a forge works great or like stainless where a forge won’t work at all?
I seem to have had personally satisfactory results heat treating it in a forge (see below). Should be fine provided you have had some experience at forge heat treatingDoes anyone successfully heat treat 26c3 in a forge?
Just some curious questions but how good are your results? Have you done any testing? Also, what kinda quenchant are you using?I seem to have had good results heat treating it in a forge. Should be fine provided you have had some experience at forge heat treating
I wouldn’t go past 1475’f, depending on the prior condition, sometimes 1450’ is better.Has anyone tried austenizing at like 1500 or so and or cryo? I know warren mention he was going to try it but I don't think he ever posted if he did.
It's not worth the additional plate martensite and retained austenite.Has anyone tried austenizing at like 1500 or so and or cryo? I know warren mention he was going to try it but I don't think he ever posted if he did.
