- Feb 18, 2016
Ok, that’s different.
Thin knives with a hamon make aeb-l seem stable in comparison. Unless the clay was identical on both sides, you will get warp.
What do you use to take out the warp during tempering?
Ok I'll give that a shot! I tried a 1/16 ss pin last time
I often stack four or five quarters, especially with thin z-wear, or s35vn. They need a lot of overclamping to correct. I think I used three correcting the spicy white.
Don’t forget that these are Canadian quarters so they will only straighten like 80% as much.....![]()
I forged all mine.I’m wondering if a stress relief cycle would help against warp. I had another blade, out of the .150 group start to warp during thermal cycle. I bent it back easily and when quenched it came out straight.
Have you tried those 3M micro film belts from pops? They work wet. I just use a squirt bottle with soapy water. They cut hard steel way better than AO. I have taken a 9" chef to 1k in 20 minutes. I think that they would work good with cork. Maybe give up to 800 then switch.I am wondering about the whole hamon thing on kitchen knives. I just used Hoss' advice and did a damascus blade totally with Gator and cork belts, no hadn't sanding required. It made me happy. I HATE hand sanding.I an thinking about doing forced patina finishes on my monosteel blades.
I got a warp as well, right after profiling the blank (0.078"), which was odd but it happens sometimes. Straightened it out the best I could. But during the heat treatment I went from Parks 50 into plates, and it came out straight. I'll have to shoot for a differential hardening on the next one. You guys have some good looking hamons.
We just received our first shipment of Voestalpine 26C3 carbon steel.
We will have more thicknesses listed soon. Let me know if you have any questions.
Hey mike. Any knives for sale?Is that banding i see?
Very impressive, are you willing to share your heat treat process?26C3 Doing pretty well as far as hamon goes... The edge holding and sharpness are also excellent. I always do some grain refinement process prior HT tho.
