Robert Erickson
- Feb 2, 2014
Whoops left out that tidbit
Thanks Larrin
So how thick do you guys apply your clay on kitchen blades? I seem to have less luck with thin unbeveled W2 blades in that .100 range than I do say with a thick .25-.28 Bowie blade that had the bevels ground down to say .050 at the edge. Do you need to go a bit thicker and higher on the thin blades?
I’d be cautious with the thin stuff. I had it warp on me after removing some material to check for hamon.
Good to knowMine was the .150 ground to a saber goring 3/4 up the blade like Warren described and still warped
Nope. But a different piece I broke off using the same technique had perfect grain
Hmm maybe a 1700 thermal cycle followed by a 1450 cycle will do the trick?
The steel on my second blade warped before I clayed it Warren. Before I ground it as well.
It warped on the first blade after I ground it to reveal hamon.
I’ll try the 1200° stress relief cycle after profiling next time.
