Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Doc,
With one piece of wood and a piece of carbon steel you could make a complete, first class knife with NO other tools, not even simple hand tools .
1) The grinder can be used to cut the steel, profile the blade, and grind it to shape. After HT it can be used to finish and sharpen the blade.Once done with the blade it could be used to shape the handle.Even polishing of the blade and handle can be done on the grinder. (All this supposes that the belts are considered part of the grinder, and not separate tools)
2) The forge can be used to anneal the steel, normalize and stress relieve the blade, and do the HT. Then it could be used to burn in the tang of the blade.
3) Tongs would be necessary to hold and handle the blade in the forge and while working on the handle burning.
No other tools at all would be needed to make a perfectly usable knife. The handle could also be wrapped leather or cord, and would not require any tools either. It could be stag crown, also.
Stacy
Stacy
