atakach,
Your knife with holes drilled, shaped by some tool, and heat treated would require at least four tools. A drill ,a file/grinder/hammer & anvil, a forge/oven, something to hold the hot blade with (tongs).
I agree the quenchant is not a tool, as anything can be used as a container and many natural liquids would work.
Lets have some fun on this:
This weekend we should all make a knife with three tool of your choice.
Take any piece of steel you want ,any handle material in the form it is normally found in.Block of wood/stag crown/pair of scales. Other additions must be raw material in form(leather/pin stock/sheet brass with no holes or slots/steel/cord/wire/etc.), no finished products ( pre-made guards,etc.), no glue is allowed.
Each tool is a separate unit, but the materials for the tool are part of it. Grinder/belts, drill/bits. You must use the tool ,not program it ( no CNC mills).
Let's allow a dremmel and accessory bits (which is really making it a variety of tools - saw,drill,grinder,sander,polisher,etc.)
It has to have a handle that is firmly secured in some fashion.
It has to be properly hardened and tempered.
Quenchant will be air,water ,or brine, and does not count as a tool.
You have 24 hours to make it in.
No other tools can be use beyond the three you choose:
No additional knives, pliers, wrenches, taps,drills,scissors,punches,chisels,saws,etc.
Making more tools is not using only three tools. Regardless of how you obtained them, more that three is still more than three.
To avoid getting silly, let's all agree that the required tooling to operate a tool is part of the tool (But can't be used for any other function) . Thus the wrench/key/bit/etc. to set up the grinder/drill/mill are not separate tools.
A hammer is a tool, a file is a tool ( but you can use several different files),an anvil is a tool, a tong is a tool , a forge is a tool, an oven is a tool,a grinder, a drill press, a mill,a file,vise,C-clamp,whetstone,sandpaper,etc.
Since we are all having fun, lets all keep it fair. You are on your honor to use ONLY the three tools, and do it start to finish in 24 hours.
Write up the entire process, telling what you did with the tools.Attach photos of the knife.
Are you guys up for this?
Stacy
