- May 1, 2013
I would be very interested in taking part in this. My detent isn't bad, but I wouldnt mind trying a lighter setup.
I'm pretty used to the detente on mine but wouldn't mind experimenting a bit. Just to be clear, though, this has nothing to do with the lockup? It just affects things in the closed position, right?
Also, I was wondering about an eccentric pin that you could rotate to fine tune the adjustment. It probably doesn't fit tight enough to keep from rotating by itself, but just thought I'd ask. That way everyone could get one pin.
I'm completely excited by this! The detent on my 0561 is WAY too light! I've cut myself twice and punched holes in two pairs of pants, plus my truck seat.
HOW DO I SIGN UP!![]()
The mod discussed in this thread doesnt apply to your needs. It is specified for people who have too strong of detent and the people who want to weaken it. The only way to increase the strength of your detent is to increase the tension of your lockbar. The other would be to have a maker or modder install a larger detent ball.
(...snip...) The larger the pin, the more it pushes the blade toward the open position and softer the detent. The smaller, well you get the idea.
I was thinking of making a pass around kit that has a selection of pins, from an average stock pin size, and then let's say 5 steps either direction from there. (...snip...)
As freewheeling notes, it may depend on how well centered the locking ball is in the detent.
I, for one, would rather try the pin change before bending the locking bar itself. Bending it yields the material on at least one side. If you go too far and have to bend it back a little, then the material on both sides has yielded. In my experience, this is begging the universe for an early fatigue fracture. I'd like to avoid that, if I can, and checking the centering of the ball by changing out pins seems least risky to me.
[/URL]I would be concerned of that if I had ever seen a single picture of a titanium frame lock that had developed a crack from stressing the material or a broken lockbar. But I havent. We arent talking about bending it back and forth repeatedly. And you have to ask yourself, do you think not a single lockbar was accidentally over extended when assemblers are fitting locks and putting these things together? Just saying I doubt they melt down every frame that they need to readjust.
While I work with titanium parts every single day here at work, I bow before your extensive and intensive knowledge of all that has or ever will happen in the knife world, particularly with respect to titanium parts. And I am awed at your belief that all failures ever have been documented with pictures here on the web and that you have seen them all and remember them. Impressive, really. I cannot compete with that.
However, it's my knife and in my own personal judgement I will try what I consider to be less risky alternatives before doing things that I personally believe to be more risky, even though I operate without the benefit of your immense field of knowledge. Perhaps you could extend me a tiny bit of tolerance here.
Actually, we are. That's how the lock bar works. We aren't talking about yielding it repeatedly, true, but that's not what you wrote. Yielding it repeatedly would lead to a fatigue fracture in fewer than 10 cycles. Think clothes hanger. The thing working in favor of long life for a lockbar is the low loading. I understand that. I also understood the point about precision machined parts. However, given my own personal life experience, I also understand about tolerance stackup, rework, and the pressure on manufacturing to hit their numbers.
May all of your knives be flawless.
A larger detent hole, not a larger ball, would increase the detent. A larger ball would lessen the detent because the ball would be seating shallower in the hole.
