BluntCut MetalWorks
- Apr 28, 2012
I don't like strop but it can be easy to use or does it (see sticky above)? Talking about hold the angle, a single atomic mass pressure otherwise your edge will end up as rounded and or overly-convexed and or dulled and or wire. So I created sub-micron diamond stones and mostly edge-leading stroke to produce sharp & clean apex. OK so, it's worked well for me but not too useful for the rest of people :grumpy:
For 2 months, I've been looking/r&d for ONE/SINGLE/GRAIL strop with the following attributes:
* Sharp: clean shave (facial hairs), smooth diagonal slice newsprint, push-cut printer paper all directions, durable
* No rounding/convexing/dulling the edge up to 2.2lbs (1Kg) pressure - pardon my use the weight unit instead of SI (pascal)
* Sharpen/touchup/polish creates 99.9% free of burr/wire that affect performance
* Work for all carbon and most stainless steels (including high-alloy such as s90v)
* Durable edge
* Almost mirror finish
* Inexpensive : less than $10 total strop life cost (assembly & operate). WAG life worth - 10K uses on average (excluded knuts).
* Super easy to use
Here is my prototype (heheh fancy word for a piece of leather & some scrap wood)
Assembly: tacky glue leather nap/rough side to wood. Rub on unicorn dust compound - tba (to be announce or tease before announce
Mora & Endura knives were stropped 16 minutes total (4 minutes per side, avg about 2 strokes per seconds) at about 1lbs of pressure. Fatigued arms cut a chunk out of my strop. Around 60% of the black swarf are from this 16 minutes of heavy stropping. Knives's edge angle pre & post stropped were unchanged (~30* & 25* included angles). Clean edge, clean shave facial stubbles, clean smooth diagonal slice newsprint.
Also I stropped s30v (bm 940) and a home made s90v knife. S30v came out great. S90v edge improved but there are carbides burr on edge, thus push cut ok but caught a bit when slice newsprint.
There are technical/physics rationales why this strop maybe/perhaps/crack-smoking possible. No point to go further, since there are plenty of sharpening experts around here boot me back to reality. Comments/kicks will be delightly receive...
* Durable edge
* Super easy to use
