BlackKnight86
Say my name, cheesers!
- Oct 14, 2003
I bet you can punch holes with an awl and "sew" it like the old Tandy leathercraft kits.....Can it be sewn?
Probably. Haven't been playing around with it long enough to bother trying just yet. I plan on experimenting with it, though. That being said, it's possible to get those double-cap compression rivets for only a little over a penny apiece, so using a lot of them won't represent much of an expense.Can it be sewn?
Well it certainly is much better than a tube sock!The ones I have on the way are black, which ought to look nicer. Some rivets would still be needed to keep the material pinched enough to prevent the edge from hitting the stitching, unless you added a welt, and then all of a sudden you've increased the required labor by a lot. And you'd need a suitable welt material, to boot. Strip rubber would probably work fine, but would be a bit expensive for the sort of low cost using this material is shooting for in the first place.![]()
Depends how you carry itWell it certainly is much better than a tube sock!![]()
Can you use the hollow rivets that are used on kydex sheaths or is the material too flexible for that?
It's been used on synthetic saddles for decades. While I'm not a fan of synthetic saddles, they have an important role in the market. They are less expensive, hold up to severe conditions and neglect, and are lighter than leather. They are plenty strong and durable for most casual riders and I think these sheaths will be, too.If you're at all like me, you've probably acquired a lot of sharp things that, for one reason or another, don't have sheaths. The volume of these means that getting nice leather or kydex made for them represents a significant cost that just isn't feasible. I just recently hit on a solution that I've been absolutely giddy about: root barrier sheeting.
It's UV-treated high-density polyethylene (HDPE). Available in rolls of varying dimensions and with a degree of flexibility and cut resistance equal to leather roughly 3x its thickness by my estimation, and dirt cheap. 20 square feet in 30 mil thickness (about that of a credit card) was $18 shipped to my door. It's ductile in temperatures down to -90° F and melts at 250° F, and can be heated with a heat gun at 240° to give it some mild stretch and formability like wetted leather. Because it's not a woven material, it doesn't need the edges hemmed, and because it's a polymer it's highly weather resistant. Not the prettiest stuff in the world, but using a weltless compression rivet arrangement I was able to knock this lightweight and durable sheath in about 5 minutes. I'm gonna' be covering ALL THE THINGS with it.
Speak for yourself, I for one, think Gaston uncovered a gem in using a tube sock as a sheath.Well it certainly is much better than a tube sock!![]()
Hmmm....we need to do some testing...what if its a black sock?![]()
I don't think this is going to make obsolete the fancier sheaths , but I can certainly see an application for machetes , axes , saws etc ; or anywhere a cheap but sturdy sheath is needed .
My guess is this should cost less than those cheap/horrible nylon machete sheaths... Would like to see how the sewing/stitching works out
