I have always thought that whatever you call a survival knife should be able to be enough tool to build a shelter for your given enviornment and be useful in gathering enough wood for at least 1 night. Add in that this is the minimum standard for me and any knife I carry should be able to perform all this before needing any resharpening. Now if it is a 10in Bowie, obviously the pole cutting and firewood will go quicker but with the right skill set, a SAK will get you there too. Just not as fast. In the nicer weather, the SAK would work fine because your shelter would probably need only be a simple lean to and wood could be procured by simply picking up downed limbs. In the winter though, I prefer a heavier blade for chopping and splitting to get larger shelter poles and standing firewood. Also out here in the Great WET Northwest, batoning and splitting will almost be required to get to dry wood from the late fall till early summer. I have had and have a large collection of what other folks would call the "perfect" survival knife. All shapes and sizes and all would get the job done. Each individual needs to figure out what works for them in their enviornment. For me an 8-10in blade camp knife, say 1/4in thick, and at least 1 1/2in wide in the blade makes me smileNow my Dad is a little different. He can do everything he needs with a Case Peanut sized blade.............and an Estwing axe backed up by a Stihl chainsaw. He laughs at me with the "big knife" and he won't go any father than he can manage to transport his gear in the pick up. Different strokes fer different folks
Mind explaining how a knife is going to 1. "alert others to your position or situation with 2. some ability to navigate"?
A Survival Knife Should Be Able To........
A survival knife should be something you never have to use. If you find yourself having to use a survival knife you f--ked up somewhere.
Unless, of course, Murphy and his damnable law decides to f--k something up for you...
Then it depends on the situation. A good all around knife will be able to hold an edge reasonably well through hard use, but take an edge fairly easily when it gets a little slow. It should be able to perform whatever task you intend to use it for: shelter, fire, food, etc...
When I'm thinking of what knife I'd want with me I always pick one that I think would build a good shelter from the ground up (a good A-Frame or swamp bed setup). If it's tough enough to do that without tearing my hand all to crap, then it should do everything else pretty well.
This is taking into account that you can last a week or two without really suffering from lack of food, shelter having to be made versus found or gathered from debris, and fire having to be made (which is generally a given) for water preparation. In most places food can be found: grub worms, insects, plants, possible fresh kills from other predators. So, to me, it doesn't have to be the greatest skinner or gutter. It just has to open the animal up enough for me to get the guts out, chop off the unwanted outter parts, and -- the case of fish, if I'm lucky enough to catch one or seven (cuz, let's face it, fish have a habit of not showing up when you want them most) -- scraping the scales off. I don't use insanely complicated traps (K.I.S.S.), so whittling them isn't really a problem with the kind of knife I like.
How about tasks such as prying, ability to be used as a hammer, being able to take your weight if used as a Piton etc....do you think these worthy of consideration ?
Interesting post with some good points being made !
I take it you would be more in the heavy duty camp that the pointy Bushcrafter camp then ?
Actually, my favorite knife so far is ESEE's ESEE 5. It's gotten more use than any knife I own and that includes my BK9.
I think the little bushcrafter knives are stunning when made right. I wish I could make a definite judgement call as far as whether I like them or not, when compared such knives as the ESEE 5, but it would be doing them a disservice to give them a negative review without having ever so much as even held one.
Any knife, if used within the boundaries of its designed intention, will work perfectly fine. I haven't used any woodlore-type knives, so I don't know how strong they are exactly. I can say for certain that, with them, it seems the emphasis is on slicing and carving versus brute work.
you could signal off of a knife by reflecting sunlight, provided that it lacks a stupid "tactical" coating like ESSE and Cold Steel knives. I doubt many people have used any of these knives in a situation where a reflection off of the blade alerts the guards of the secret military base they are sneaking in to, but I could be wrong.
I believe in a durable, comfortable blade between 4 and 5 inches in length that I can carve with. I use a collapsible Wyoming saw for wood processing work, and a small hatchet for chopping, leaving my Mora Clipper and Victorinox Ranger to do the fine work. However, if I could only have one tool, I would take my Falkniven A1, the perfect survival knife. It is comfortable, stupidly durable, and can chop and baton through anything. Its overkill when I have the aforementioned tools, however.
To see what a survival knife should be, look at the designs of the Becker BK9, the Falkniven A1, and the RAT 5. They really are perfectly designed tools, and it is mere personal preference between the three.
