razorburn
- Mar 26, 2007
no coatings planned at this time. The kukri, trailmaster , etc will be high satin finished
Awesome news,I can hardly wait.
It seems to be a YMMV thing. I haven’t noticed any significant dulling on my end yet, but then again I consciously apply pressure on the spine as I unsheathe and resheathe.Not sure why theres so many complaints about the sheaths; ive been using them for years never saw any dulling of the blades,and i like that i can remove the belt loop and add a teklok to it.
As promised, testing 4034SS. Andrew took the time to take an off the shelf Outdoorsman Lite in 4034SS (4mm thick) and ran it through its paces for you all. Spine whacks at weights far beyond what we normally test and and even further beyond the capability of hand held exerted force. Over 200 1" rope cuts (definitely could've kept going - he can chime in on that), bending further than would ever occur by hand. Now, take this 4mm knife and double it in thickness and imagine the strength. We hope you guys will watch this and understand that it is not a crappy liner steel and when done properly it can be great.
<iframe width="560" height="315" src="" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I believe the speed will be different until Terminal Velocity is acheived, that being the maximum speed an item can fall due to gravity. The heavier weight should achieve this speed faster. *It's been a really long time since I took any science class, so please correct any mistakeNice video, but how does the “accelerometer” work? Wouldn’t the falling plates fall at the same rate (the rate of gravity). The acceleration would be the same regardless of the amount of weight. The stopping force would be different, due to the change in mass, but since the blade is free swinging, it is not stopping the momentum.
n2s
I believe the speed will be different until Terminal Velocity is acheived, that being the maximum speed an item can fall due to gravity. The heavier weight should achieve this speed faster. *It's been a really long time since I took any science class, so please correct any mistake![]()
It's not just falling...it's pivoting on an axis, creating torque. The heavier the weight, the more torque. Can google the physics of a trebuchet for more info...very similar.
Yes, the momentum is different, but the knife is not trying to stop the motion of the device, it is just impacting at a constant rate of rotation. On a trebuchet, an increase in the counter weight can be used to throw a heavier projectile at the same speed, or to extend the arm which would throw the same projectile at a greater speed.
n2s
The knife goes faster with heavier weights. The weight is not in free fall. Its force toward the Earth is resisted by the rotational inertia of the arm and knife. More weight-> more torque -> more knife/arm acceleration -> more knife speed. As someone said, you can see it going faster too. (Aced physics 110 decades ago.)Yes, the momentum is different, but the knife is not trying to stop the motion of the device, it is just impacting at a constant rate of rotation. On a trebuchet, an increase in the counter weight can be used to throw a heavier projectile at the same speed, or to extend the arm which would throw the same projectile at a greater speed.
n2s
I'd prefer AEB-L or 12C27, but my guess is that 4034 is the highest carbon member of this class that can be blanked
