- Aug 21, 2014
Cobalt starts all the cool threads.
I know. 😏
Here is another issue that comes up with power sharpening. With steels, the higher the alloy content the lower the thermal conductivity. So for example, a stainless steel conducts heat at a lower rate than a plain carbon steel. This is good and bad. Higher alloy content does resist heat damage better. But because it is a lesser conductor of heat you may not notice the localized heating of the edge because of it. Of course blade design, thickness, width all come into play as well.
The rule has always been that if the blade is warm, you probably damaged the edge. If at no point the edge is warm you are probably fine. If you use power tools. I have never had a warm edge by hand sharpening.
I don't care whether you buy the theory or not and I'm not trying to convince you, but you and others seem to be missing the point. According to the person that did the testing (Roman Landes, a German metallurgist), you won't be able to feel the heat. We are talking about at the apex where there's little "thermic mass" (to quote Roman Landes). The heat (which has been measured at 2000 degrees Celsius) only last a nano second and will come and go before you have a chance to feel it.
if cost isn't a factor, why was modified infi used for the basic series?
Grinding generates energy (heat) and every step of sharpening is grinding even the strop.
This heat can be sucked away by the right coolant such as water.
If the grinding action lacks the coolant, the heat goes mostly into the torn out part and the body (blade/edge) it was torn off.
It becomes obvious to see the induced energy when you see the sparks fly (Burning steel!!).
I know it's about as unscientific as it gets but with my TGLB and my SOB, I can tell a difference in the sound and feel of the steel going over the sharpening rods. The SOB seems harder and so far it seems to hold an edge better.
