try for 5-10 min's not seconds alsoThe trick may be holding a steady temp just above non-magnetic for 10+ seconds.
TikTock said:I now soak at a low temp, like 1400, for 5 mins, then ramp to 1435, hold for 4 mins, then quench. The lst 5 blades ive done using that have looked smokin'!
looked smokin'
Dan Gray said:dave what do you mean by
OK I CTikTock said:Just meant they looked good, with more of the smokey action tha I wanted vs just a wavy line.
Trout Tamer said:The 2 blades of 1095 that I quenched in water both cracked. The blades I quenched in motor oil didn't harden as fully as I wanted them to. The blades that I've quenched in ATF (automatic transmission fluid) have had a nice post-heat hardness to them... bottom line, I've had lots o' bad luck quenching 1095 in water.
